OBD2 ecu tuning question
I've done a lot of research for boosted applications for my ek. The only thing I'm stuck at is the ecu. Is the easiest way to go about this (trying to stay obd2) to get a p28 ecu with a conversion harness? Would it work properly if I take it straight to a place to get it tuned?
This is what I'm looking at right now: http://www.phearable.net/shoppingcar...vtec-p-31.html
Using an obd1-obd2 harness wont work properly with it?
If you loved me, you'd all sell me your magic cards to me today
use all your OBD2 stuff then get a jumper from OBD2 to OBD1. You will need to figure out if you are OBD2A or OBD2B for the jumper.
I also see you are in MD, the OBD1 ECU will not pass emissions.
