Resistance specs for TPS?
Old Sep 18, 2013 | 08:07 AM
fragmare's Avatar
Default Resistance specs for TPS?
I've got my throttle body off of my 93 DX today, cleaning and tweaking my FITV, in a last ditch effort to tackle this idle problem before I go out and purchase a new FITV. It revs up to about 2100 RPM on a cold start then will rev between 1000-2000 RPM before settling down and gradually dropping to 700 RPM at full operating temperature.
I figured it would be a good idea to test the resistance of the TPS while the TB is off. I did a sweep test, starting with the throttle closed and slowly rotating it to WOT. No dead spots.
My question is, is there a set amount of resistance (in ohms) that I should be seeing when the throttle is closed and at WOT? I took a look through the Honda manual and only found the voltage test to perform when everything is bolted back up to the car.
Old Sep 19, 2013 | 02:25 PM
Lizardslap's Avatar
Default Re: Resistance specs for TPS?
May as well adjust it because its gonna be off
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
FrostyEG
Apr 20, 2014 10:41 PM
import-tooner
Jul 19, 2013 06:39 AM
portenio78
Engine Management and Tuning
Sep 2, 2012 11:52 AM
EH3 JR
Nov 6, 2009 09:57 PM
