H4 to double H1 conversion dilema
Recently i purchased facelift headlight’s for my CRV gen II ’02, the fit perfectly only I made a mistake in connecting them.
I assumed that the H4 connector, which consist of 3 contacts ( –negative +low beam and hi beam+ ). The h4 bulb consists of two different “glow wire’s”
Which both burn separately by using hi end low beam. So I thought that it was easy.
However, after connecting and measuring it appears to go a bit different.
By using low-beam the hi-beam light burns weakly (and I measure 6v) and even the light on the dashboard burns weakly.
So I thought I made a mistake but any other configuration makes it worse.
At first i assumed that i connected the - mass/negative of on of the two light’s on one of the 2 + hi/low-beam connectors
When I re-measured white one of the lights in the low beam position of the switch, I measured +6v whiteout the light connected +12v on the hi-beam connector.
when I switch to hi beam the same wire has 12v en non on the low-beam wire
So the two h4 connector share a wire ore have double (phase) positive/+ connection??
My lights are off I’m totally lost white this one.
Problem salved!
The Mass in the H4 connector is switching from position when you switch from hi to low beam.
As an example
Hi-beam
cable 1 +
cable 2 +
Cable 3 -
Low-beam
cable 1 +
cable 2 -
Cable 3 +
From the 2 H7 lights I connected the shared cable from both of the lights to the cable witch always have 12v+
The -/mass/ground/negativ is shifting not the + in the H4 connector.
As an example
Hi-beam
cable 1 +
cable 2 +
Cable 3 -
Low-beam
cable 1 +
cable 2 -
Cable 3 +
