NEED HELP ASAP WITH 1991 CIVIC DX
i have a b16A in my honda civic dx 1991, it hasn't ran right since i bought it. buddy that i bought it off of said it needed a new computer because it wasn't running properly, it wasn't accelerating right bogged down a lot. and when ever i put it in gear 1 or any gear if that and push the gas and let off the clutch it seems to die [stall out] i switched the computer from the pm6 to the pr3 and still nothing, the little red light on the ecu blinks i believe 3 times, it's two slower red blinks then a quick blink. and it constantly does it repeating it in that order over and over. anyone have any idea to what is the matter and or how to fix this?
A long blink counts as 10. A short blink counts as 1. So two long and a short is 21. Makes sense right? Just for future reference, I want you to be able to pull more numbers since you will probably get different check engine lights as you try and get this running. CEL code 21 is the VTEC spool solenoid. Which means you are revving the motor up high enough to engage VTEC and it's spitting out that code.
If your car is dying it could be many many problems. It is probably a bad wiring job or vacuum line routing. Try and get some photos. Lots of them. A general shot and then a picture of just about every sensor you can find and someone will be able to spot a flaw and that will get you going.
so basically you want me to take multipul pictures of my engine and the bay and the wireing harnesses?
Well i did it, and here's the link for the pictures.
http://s880.photobucket.com/user/jbo...civic%20engine
Correct me if I'm wrong, but this is your car and engine here:
D15B2
1988–1991 Honda CRX DX
Bore and Stroke: 75 mm × 84.5 mm (3.0 in × 3.33 in)
Rod Length: 134 mm
Compression: 9.2:1
Power: 92 hp at 6,000 rpm (US)
Torque: 88 lb·ft at 4,700 rpm
Valvetrain: SOHC (4 valves per cylinder)
Cam Gear: 38 tooth
Piston Code: PM3
Fuel Control: OBD-O DPFI
Redline: 6,500 rpm, 7,200 rpm rev limiter
Head Code: PM5
ECU Code: PM5/P04
Rod Length: 134 mm
Compression: 9.2:1
Cam Gear: 38 tooth
Piston Code: PM3
Head Code: PM5
ECU Code: PM5/P04
well yeah the stock thats the stock DX, i have the B16A in it as we speak, i can take more pictures of the engine to show more so you can have a better look, or others? and the guy i bought it off of said he had it running last year in the summer and put it in his garage after the summer for winter, and when he brougt it back out it wasn't running properally because of the ECU. but i'm getting the code error 21 On my ECU and that is it..? so what should i do about that? replace the solenoid? or rewire it i dunno? lol PVC the cords inside the clip?
As for code error 21,
On the ECU, looking at it from the side the connectors go in:
A ------- B ------- C
And it is counted:
1 3 5 7 ...ect
2 4 6 8 ...ect
So it should be the first clip on the left, bottom row of wires, 4th one in. If there is no wire there then that's the problem. I don't remember if there is a wire there from the factory. But the previous owner would have had to splice his wire into there.
alright i'll check quickly and take some extra pics just give me a few minutes. and i'm honestly thinking he took out his old ECU and sold it separately in my honest opinion, because i had to replace a few things now. so i think he took a couple of things out and sold them or something. but i put everything that i needed to have it running again back in. so i don't really know what else to say.. maybe plug an OBD detector in and see what the problem is? but im not to sure if this model comes with one..
Alright i checked the wiring, and it does have the A8 wire connected in it.
And here is more pictures.
http://s880.photobucket.com/user/jbo...ideshow/Engine
Is your car OBD0? Or is it OBD1, or do you know? I'm not sure how a car with different electronics would run. I will assume it is still OBD0 though.
Have you tried to do a tune up? New spark plugs, wires, distributor cap, oil change, ect? That and possible some new filters and checking the connections on all your important sensor plugs (MAP, IACV, Distributor, ect) may get you some where. You should also check into you FICV since I have heard that causes a lot of problems. Do you have a tach? Can you read the idle RPMs?
and how do i check the voltage on the ecu and solenoid? use a tester light on the wire? or what? Lol sorry i just don't wanna screw something up.
Honestly, when I have an issue I try to google it and find someone with similar symptoms. Then you can work from there. It's hard to say exactly what is causing your bogging. I know a bad MAP sensor can cause bogging. But there are a million different things that can cause bogging too. So I still can't say, without a shadow of doubt, what is causing your issue.
Try bouncing some ideas off of me. What are you thoughts on what could be wrong? Brainstorming can help figure stuff like this out.
One last idea though, try and do a compression test on each cylinder and post your numbers if possible.
I'm not sure if a faulty clutch could cause your problem either. Discribe the idle. Or maybe get a video of your car idling. Sound is really helpful for these types of things.
its an Obd0, and at first i thought it was cause i had the pm6 ecu so i bought a pr3 and put it in, and still the same thing, now its saying something is wrong with my solenoid. but i don't think that would cause the bogging or the idle problems. in my honest opinion i don't think there is anything wrong with the motor it's self or the spark plugs or the fuel pump. so maybe the distributor? i don't know. because it starts up fine, sounds alright untill i put it in gear and push the on the gas, then it starts to die down and such.. like i can record a video upload it and show you what i mean if that helps at all?
BUT FIRST. What does the block say RIGHT HERE in this picture:
http://postimg.org/image/qh8fukq09/
i think i just realized the problem.. LOL i'm missing the solenoid completely.. look closely..
http://s880.photobucket.com/user/jbo...eshow/Solenoid
What is stamped on the flat pad circled in this pic? Or does that pad look like it's been sanded down so you can't read it?
