94 accord lx, Wont start after sitting for a while
Old Sep 17, 2013 | 06:11 PM
Runeknight95's Avatar
Default 94 accord lx, Wont start after sitting for a while
Heres the issue on my buddies car.
The car will start in the morning, get to work but around 12-1 it will not restart. If you wait 30 mintues or so, it will start up.
This was going on for a long time but now the car wont even start after we started messing with it. *****Car turns over and then dies******
From reading this forum Ive guessed
-Main relay
-Coil
-Thermostat ECT (the one under the distributor)
-Distributor
any other ideas?
Main relay is replaced.
Coil was replaced no change
****???***ECT was switched out real quick, just unplugged the plug from the harness and put the new ECT in without installing it, would an ECT work if its not screwed in to at least start the car or should I install it completely?
-Could this be the distributor? that part was the last part I didn't try becuase its a $180 part compared to the 50/52/and 20 ive spent on relay, coil and ECT
Old Sep 17, 2013 | 06:41 PM
hatchdrvr's Avatar
Default Re: 94 accord lx, Wont start after sitting for a while
Have you checked to see if you're getting spark and fuel?
Old Sep 17, 2013 | 07:47 PM
Yes, spark plugs are wet and I used an inline spark tester. I also forgot to mention the coils on plug and spark plugs are brand new as well (replaced like 5k miles ago)
Old Sep 17, 2013 | 11:46 PM
hatchdrvr's Avatar
Have you checked all of your grounds?
Old Sep 18, 2013 | 09:02 AM
As in the big 3? Like ground from battery to chasis, and chasis to engine? Or minor connections somewhere?
Old Sep 18, 2013 | 03:15 PM
hatchdrvr's Avatar
The ground on the thermostat housing particularly.
vaderman_x
Jun 9, 2019 07:00 AM
leflore
Sep 1, 2016 05:33 PM
live_again_integra
Jan 4, 2007 05:42 PM
90crxdxb16
Nov 17, 2006 03:54 PM
mingbling96
Jun 1, 2006 06:51 PM
