B18C Idle Problem-Please Help!!
Old Sep 17, 2013 | 02:15 PM
Going JDM's Avatar
Default B18C Idle Problem-Please Help!!
Hi everyone, I have a 96 DX that Ive swapped a OBD2 B18C GSR in. It’s a pretty mild setup. It’s basically bone stock except for a few bolt ons. It has Skunk2 Pro Series 1 cams, cam gears, valve springs and retainers, HKS exhaust, ARC intake, etc.
I am running a OBD2A ECU (P72), and a Chase Bays CM1 harness. The car runs, but idles rough. It surges pretty bad and idles from 1100 to 1400 rpm when warm. I’ve cleaned the FITV (Fast Idle Thermo Valve), IAC (Idle Control Valve), adjusted the timing, adjusted the idling screw on the throttle body, made sure the harness is correctly connected, etc. The only check engine light Im getting is code 11 (99% sure). I believe this is a cooling sensor code.-No biggy
I am using an Edelbrock Victor X manifold (4760), and Im thinking that I have a vacuum leak or something is not connected. Can someone please give me direction on which lines are supposed to be connected to the back of the intake manifold? Ive searched and found little to no information.
This is what I have: (still some things to tidy up)
1. FPR
2. Plugged
3. Brake Booster
4. Plugged
5. Plugged
6. MAF Sensor
7.Plugged
8. Plugged
9. Plugged
Old Sep 17, 2013 | 03:59 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: B18C Idle Problem-Please Help!!
There is no code 11, pull the code with a reader or the paper clip method and post it. Also you'll need to do the correct idle adjustment, there's a write up in the FAQ.
Old Sep 17, 2013 | 04:05 PM
whoaitzbrain's Avatar
Had a similar problem with my b18c R .. Turned out to be a bad ecu. Try swapping out ecu first.
Old Sep 17, 2013 | 04:38 PM
Going JDM's Avatar
Hmmm, ok. I did the paper clip trick. Im trying to post a video of the CEL flashing. Ill get it up soon...(thats what she said)
Also, I called Chase Bays today and told them the situation. They said they had a similar problem and for me to check the MAP sensor. He said he replaced the MAP sensor on one of his cars, and it fixed his problem. I'll try this tomorrow.
Old Sep 17, 2013 | 05:32 PM
Going JDM's Avatar
Heres a video of the flashing CEL. Let me know if it doesnt work.
Old Sep 18, 2013 | 01:38 AM
Technical Hero
Thats a strange looking flash, almost like code 2 (2 quick blinks). 11 would be be one long and one quick. I'd try a friends ECU and see what it does.
Old Sep 19, 2013 | 02:57 AM
Runnerdown's Avatar
So wait you have pro 1 cams on a stock ecu? Of course the cars not going to idle/run right.
Old Sep 19, 2013 | 03:06 AM
Fliptard's Avatar
that's code 20. ELD and Electrical Load detector. Check ALL your fuses. I don't know much about them besides they are in the underhood fuse box
Fliptard's Avatar
or* not and
bantum1cwa
Mar 5, 2014 06:25 AM
momodc221
Aug 16, 2013 05:10 AM
leadfoot78
Sep 16, 2003 10:36 PM
user 996328629
Jun 14, 2003 10:49 AM
