Fusebox acting up?
Old Sep 17, 2013 | 10:26 AM
SiRCiviC94's Avatar
Default Fusebox acting up?
I have my car starting fine but the fuse box is dropping voltage in those auxiliary slots I use for my gauges making them give Waky readings. (Only on the on ||| position) which makes the issue hard.
I found a bit of water in the trunk and my remote
Wire in water for the CD player...but I think the starter just started working on its own. Car is a 95 eg swapped boosted etc.
Ignition switch or harness issue?
Old Sep 21, 2013 | 09:23 AM
fcm's Avatar
fcm
Old Fart
Default Re: Fusebox acting up?
If it only happens in position III, it points to the ign. switch, a common problem, [ign. switch problems] on older Honda/Acura. 94
dhernandez_9117
May 22, 2023 02:56 PM
EGhachiback
12
Jun 11, 2014 03:44 AM
JuneBugDrfter
Nov 30, 2013 07:57 AM
saemoonyang
Nov 18, 2008 02:37 AM
