Dash light fuse
Old Sep 17, 2013 | 02:09 AM
76 camaro car's Avatar
Default Dash light fuse
Can someone tell me which fuse is for the dash lights? I leave my house every weekday morning when its dark outside and have no dash lights or clock. Thanks
Old Sep 17, 2013 | 05:05 AM
Joyboy's Avatar
Default Re: Dash light fuse
How about a tad more information, like year and model to start with
Old Sep 17, 2013 | 08:40 AM
Lost Again's Avatar
Was this happening before or after you swapped out the cluster?
I think the OP has a 5th gen. #32 in the underhood fues box "feeds" the combo switch. I'd test the dash dimmer switch as well. Lights on, ground the red wire to the dimmer - dahs lights should go full bright.
Old Sep 17, 2013 | 11:31 AM
Oh yeah, Its a 94 accord. Lost, I havn't changed the cluster yet. I think you are right about the dash dimmer switch. I checked all the fuses under the hood and they are all good. I tried switching out the clocks and the new one did not work either. I have power going to 2 of the 4 wires that plug into the clock. Could the dash dimmer switch stop the clock from illuminating too? Thanks
Old Sep 17, 2013 | 01:51 PM
Lost Again's Avatar
Check the #1 10amp fuse in the under dash fues box.
Old Sep 17, 2013 | 02:40 PM
Thanks, That could be it. Can't check right now though,we are having thunder storms. Will let you know.
Old Oct 22, 2013 | 03:31 PM
Still having the same problem. I checked all the fuses (drivers kick panel & under hood) and they are all good. No dash lights and no clock. Anyone have any idea's on what the problem could be? Lost, Is there an easy way to get to the dash dimmer switch red wire?
Old Oct 22, 2013 | 03:48 PM
professorman's Avatar
The dimmer pops out. Use a tiny knife or any other non-destructive prying mechanisim to pry below the lower side of the switch housing.
Old Oct 23, 2013 | 01:32 AM
Thanks, I will check it out today.
Old Oct 23, 2013 | 04:18 AM
Tried grounding the red wire on the dash dimmer switch and still no dash lights or clock.
Old Oct 26, 2013 | 08:24 AM
Lost Again's Avatar
So the clock never works?
On the dimmer.....confirm that the BLK wire has continuity to ground. Also with the head lights on - the RED/BLK should have 12v. Please confirm.
Old Oct 28, 2013 | 01:26 AM
Will check them today and let you know. Thanks
Old Oct 28, 2013 | 04:49 PM
katinhat's Avatar
My clock is starting to flicker, but is lit 90% of the time. My kids asked why I don't fix it, hah. Not worth the money or effort, I said.
Old Oct 30, 2013 | 07:04 PM
jorgep82's Avatar
Mine went out a month ago. turned out to be the dimmer. Dimmer was bad. I got a dimmer in ebay for about 8 bucks. Replaced the previous one a my light came back on; however, one had blown, accessed cluster and got light bulb replacement at autozone. if you need to access the cluster You'll need to remove the center console if you do this and feel the urge to clean it USE compressed air, I removed stuff with a screwdriver and now my D4 light won't light up (there's a connection between the stick and the D4 light and I think i shorted it) I don't know how to fix that now.
Old Oct 30, 2013 | 07:09 PM
jorgep82's Avatar
My clock also won't turn on right, sometimes it's on and sometimes it's off, but that's because the connection to the clock is bad. I need to remove the radio and wiggle it to connect right.
Old Nov 4, 2013 | 02:03 AM
I've been out of town for about a week,but will check today. The clock did not go out all at once, it would work awhile and then go out. Then work awhile and go out. It has not come on now in about 2 months.Same thing with the dash lights. I can get a used dimmer switch from the local u pull it if you think that could be the problem. Thanks for the help.
Old Mar 30, 2014 | 07:55 AM
Well after replacing the clock and the dash dimmer switch I still have no dash lights or clock. Now that the time has changed (DST) its black dark when I leave in the mornings again. I am at a loss as to what to try next. All I can think of is I have a bad wire that supplies power to the dash lights and clock. Anyone have any ideas of what I can check next? Thanks
wildcat1998
May 12, 2009 04:56 PM
NarlyStarz
Nov 15, 2008 05:07 PM
Rat_Bear
Nov 11, 2008 12:22 AM
JDMDC5888
Mar 27, 2006 01:26 PM
CRXsiproject
Oct 19, 2005 12:15 AM
