95 LS ABS issue
My ABS light is on while engine is running, thus there is a problem with the ABS system. I attempted the jumper/ light flash test and the light would just stay illuminated as if I didn't have the jumper wire on the connector. I'm kind of confused. Any ideas? TY in advance
Have you checked to make sure you weren't low on brake fluid?
Have you checked your abs sensor?
http://www.team-integra.net/forum/bl...bs-sensor.html
