92 Accord Ex Maddening Bogging
Old Sep 16, 2013 | 09:31 AM
per4manz's Avatar
Default 92 Accord Ex Maddening Bogging
Hate to beat a dead horse, but was hoping for a plan of attack before I decide to sell this car as is.
Have had bogging issue on and off for a couple of years since engine was supposedly rebuilt. I say supposedly because I have a feeling the mechanic who "rebuilt" the engine may have dropped in a Japanese import instead of actually rebuilding it (based on my current mechanic's statement after changing water pump that the timing/belt side of engine appeared to have an extra pulley that he has never seen on an accord of this year). Engine is stamped 22A6 (no F - weird?). Anyway to tell if it's an import?
Anyway, I have cleaned the EGR ports (on vehicle), replaced the EGR valve, cap and rotor, ICM. Checked main relay for broken solder joints, but found none - plus car doesn't die at all, just bogs at ~2500 rpm. It's been awhile, but I think I checked and cleaned the MAP sensor and cleaned the IAC.
Hasn't been driven for awhile until last night. Bogged like a mad man for a bit, then all of sudden was running smooth as a baby's butt, but know it will happen again. Makes me want to attempt one more time to fix the problem before I dump it.
Oh, and no check engine light.
Any help constructing a plan of attack would be greatly appreciated.
Old Sep 16, 2013 | 03:00 PM
Lost Again's Avatar
Default Re: 92 Accord Ex Maddening Bogging
Check and clean the main ground on the t-stat housing.
Check or replace the O2 sensor and be sure there are no exhaust leaks.
Old Sep 17, 2013 | 10:05 AM
per4manz's Avatar
Thanks, Lost Again. As soon as I get the chance I'll take a look and report back.
Old Sep 19, 2013 | 12:02 PM
GK2's Avatar
GK2
How is fuel pressure? Possible fuel pump or filter?
Old Sep 19, 2013 | 12:25 PM
mrj_accord's Avatar
i guess the first thing i would check is for small stuff.
fuel filter might be clogged
check resistance through all fuel injectors
check fuel pump and filter in tank. (might have debri floating around and is getting caught on the filter and not enough fuel flowing thru gas lines)
mtnblue
Jun 7, 2016 02:39 PM
Jmb106jr
Jan 28, 2011 11:25 AM
Frank Allen
May 6, 2009 12:57 PM
The_Caged_Bird
May 27, 2008 03:58 PM
dogpile5
Apr 9, 2006 10:25 AM
