Difference between ball type and fork type lca
Old Sep 16, 2013 | 08:07 AM
Ronnn's Avatar
Default Difference between ball type and fork type lca
My car is an EG6
Some of the rear bushings need to replace
I am considering replace the whole lower control arm instead of just replace the bushing (since labor is expensive in my city). As those arms are getting old, it may be better off to replace together.
Ok my question is:
As my EG is using the ball type lca, it seems hard to find these type of lca
All the search came up were fork type lca
Any pros and cons for the fork/ball type?
I think there must be some reason on my EG6 and DC2R uses ball type, but other EG use fork type.
Old Sep 16, 2013 | 01:27 PM
94EG8's Avatar
Seagull Management
Default Re: Difference between ball type and fork type lca
They stamped steel (ball type as you're calling them) are lighter than the cast iron version. They aren't any stronger. For the most part one works as good as the other, but you will have to replace both rear shocks if you go with the cast iron version and you may need to swap swaybar endlinks. Do not use base model civic LCAs as they will not have provisions for a rear swaybar! Get ones from an integra or loaded sedan.
Old Sep 16, 2013 | 08:43 PM
Ronnn's Avatar
Thanks
And I do plan to change the shock, so not much issue on this
jermo
14
May 10, 2019 03:07 PM
LKSi
Mar 16, 2011 09:06 PM
SdGSR01
Sep 20, 2004 04:14 PM
rastropovitch
Feb 10, 2004 12:53 PM
