itr valve questions
Hello all, i picked up a b16 head the other day, and the guy told me it has itr intake valves and stock exhaust valves. I looked it up, and i guess its known all b series valves are the same physically. So when i picked up the exhaust valves from the guy, i noticed the valve faces are bigger than the b16 ones, and is indeed the same size as the intake valves already in. So my questions are:
1) are the itr valve faces bigger than every other b series valves?
2) are the intake valve faces bigger than the exhaust, or vice versa?
3) what can i use to clean the bottom of the faces, or the whole head?
Thanks!
Thanks!
all B exhaust valves are the same and identical.. no face here face there bigger or different
all B intake faces are identical and same.. no face bigger or smaller from one another
ITR valves have tuliped/narrowed stem (behind the face of the valve)
thats about it... you can barely see this in an assembled head though
they do resemble the narrowed stem of supertech valves
