AEM wideband gauge install, need help
Old Sep 15, 2013 | 08:22 PM
Manifest113's Avatar
Default AEM wideband gauge install, need help
hey guys i have a car that a h22 swap had been done by the previous owner and same with the gauge. the wiring was tied into the aftermarket audio harness(power, ground, output wires) I didnt notice it till i had the whole harness pulled out bc im replacing the headunit and ive never installed a wideband before. is this standard way to install these wires from the gauge? if so what do i tie the two output wires into? and if not what is the usual way? any help would be awesome and yes i did try to search here and online and im still lost.
Old Sep 15, 2013 | 08:44 PM
jbpnoman's Avatar
Default Re: AEM wideband gauge install, need help
You say you tried searching...but did you actually try? Because "AEM wideband wiring" on Google gives you this. You don't even need to scroll.
Assuming you aren't running any kind of datalogging, red goes to power, black goes to ground, and white and blue just get capped. If you are running external datalogging, you run white for a voltage output, using black as a unified ground, or you use blue as a serial (raw data) output.
sohcturbo92vx
Apr 11, 2012 09:37 PM
gmbdelsol
Apr 10, 2011 12:46 PM
2.2 teg
May 5, 2006 09:05 AM
ScrapinSi
Sep 2, 2003 11:23 AM
ceemarun
Jun 24, 2002 06:57 PM
