Transmission & Drivetrain Gearboxes, Differentials, Clutches
rpm diff in same "gearing" what gives??? pics
Old Sep 15, 2013 | 01:11 PM
jdmh22eg2's Avatar
Default rpm diff in same "gearing" what gives??? pics
ok so me and a buddy were talking about diff **** on our cars and something does not add up.
his car teg w/16" wheels, itr motor, b16 trans (em1)
my car hatch w/14" (but road sign radar verified), gsr, usdm itr trans
he his turning 4k rpms at 120kmh (74 ish)
me 3k rpms at 70mph
so WTF. i know both trans are supposed to the same minus mine being lsd pics below
mine
his
Old Sep 15, 2013 | 01:20 PM
sportsman1539's Avatar
Default Re: rpm diff in same "gearing" what gives??? pics
Maybe you have an ls 5th? See what your rpms are in 4th at 70.
Old Sep 15, 2013 | 01:24 PM
jdmh22eg2's Avatar
well as far as i know this is a VIRGIN r, i am 3 rd owner since new and my buddy bought of og owner of the R when they went k
*** edit trans was rebuilt by OG r owner, very possible its ls 5 th
Old Sep 15, 2013 | 03:13 PM
94EG8's Avatar
Seagull Management
Chances are you don't have an ITR trans. An LS 5th wont drop you 1000rpm. 300 - 600 rpm depending on who you talk to. If you're really lucky it's an LS 5th and the tach just isn't all that accurate.
Old Sep 15, 2013 | 03:24 PM
jdmh22eg2's Avatar
well considerig it has a j4d stamp AND a dc2 vin tag i say its all good
Old Sep 15, 2013 | 03:32 PM
jdmh22eg2's Avatar
i will try and get my hands on another rpm cluster to verify rpm's
Old Sep 15, 2013 | 04:47 PM
94EG8's Avatar
Seagull Management
Never trust the stamp or VIN tag. Sometimes people will swap guts. It's not always with malicious intent either. I've had to swap cases before due to a cracked/broken case.
Old Sep 15, 2013 | 04:51 PM
jdmh22eg2's Avatar
tru, i belive after thinking about it is combo of cluster and ls 5th. i am running stock gsr ecu and my cross over on rpm's like 4800 so that makes me think its off a few hundred anyway
also considering i am 3rd owner of trans and my buddy second and NEVER opened it himself and he bought from OG r owner. i do belive only thing done was (if any) ls 5 th
Old Sep 16, 2013 | 03:24 AM
jdmh22eg2's Avatar
did this this am on the way to work and got 4500 rpms' tho if my tach is off like i am starting to think it would put me closer to 5k
Old Sep 16, 2013 | 04:11 AM
yungmulacrx's Avatar
Be careful with reading stock tachs.. I know mine is off bye a 1000 rpms at 8000.. My stock tach reads 4400 when vtec engages which is 5100..
Old Sep 16, 2013 | 05:04 AM
Sounds like an ls to me. My b17 tranny which is basically the same gearing as an itr, is at 4000 in 5th at 70. My old ls would read 3200 at 70 in 5th
Old Sep 16, 2013 | 05:34 AM
jdmh22eg2's Avatar
yea i think i have a combo deal
miss reading tach and ls 5th
Old Sep 16, 2013 | 05:48 AM
kyden's Avatar
the rpms look right for an ls transmission. my stock ls is around that rpm at 70.
Old Sep 16, 2013 | 07:21 AM
I think your whole tranny is an ls. Doubt the tach is that far off
Old Sep 16, 2013 | 07:50 AM
jdmh22eg2's Avatar
nope gears are to close ratio for LS.
Old Sep 16, 2013 | 08:20 AM
Ok so drive 4000 rpms in 3rd gear and tell me what your speed is. Keep in mind with smaller tires your rpms will be higher which is why I think you have an ls tranny. Small tires on an ls tranny can make it feel somewhat short.
Old Sep 16, 2013 | 09:49 AM
jdmh22eg2's Avatar
well my "small" tire is LARGER than a 205/50/15 so that rules your idea out. and rpms are read off the TRANS
Old Sep 16, 2013 | 10:13 AM
Hmm well I thought you had small tires but it was the 14" wheels that I read. And yes tire size affects rpms too. Good luck with your ls trans.
Old Sep 16, 2013 | 11:20 AM
projectTeG's Avatar
Looks to be a ls trans. Match your buddy gear to gear.
Ls 5th in a 4.4fd gearbox would have 2-3 mph less than a straight ls
Old Sep 17, 2013 | 05:30 AM
kyden's Avatar
um, no. road speed is read off the transmission. RPM is read off the distributor. rpm is rpm, regardless of transmission is in the car.
Old Sep 18, 2013 | 02:02 PM
jdmh22eg2's Avatar
so it turns out it WAS my cluster. i put a cheap wire in tach in car and bam proper R rpm/speed. also swapped in a spare rpm cluster and it shows proper rpm/speed for the R trans.
speedciv
Mar 28, 2011 06:57 PM
wunfstgsr
Nov 28, 2009 10:51 PM
R.Storvick
Oct 22, 2009 12:58 PM
jfoster
Jun 21, 2005 07:04 PM
MCoupster
Jun 2, 2004 09:47 PM
