93 honda accord missing/sputtering
Old Sep 14, 2013 | 02:32 PM
toyolla86's Avatar
Default 93 honda accord missing/sputtering
so i have been troubleshooting this stupid car for months now.
it used to run fine when cold, then once warmed up it would start missing. now it misses even when cold.
symptoms:
the gas mileage has progressively gotten better (24mpg and now 26.9 mpg)
it started after one of my spark plugs popped out and the engine shook like crazy still i put the plug back in.
it seems rythmic. not really too random. so it seemed like it was only one cylinder doing it. maybe 2 cylinders now.
things i already tried:
i replaced the iacv... no change.
i replaced the little spark thing inside the dizzy.... no change.
i replaced spark plugs... no change
i rebuilt injectors... no change. (although i am still pointing towards them)
things i think it may be:
some vacuum leak
a sensor i dont know about
fuel filter
fuel pump
the fact that the mpg is being affected makes me think that something in the fuel system is clogging up and starving gas which is saving me gas.
anyone have any insight? thanks
Old Sep 15, 2013 | 12:04 AM
holmesnmanny's Avatar
Default Re: 93 honda accord missing/sputtering
spark plug popped out or spark plug wire popped out ?
Common sense says if your spark plug wire pops out you need to ditch those cheap wires and get real wires from NGK or Denso
Old Sep 15, 2013 | 10:20 AM
toyolla86's Avatar
spark plug popped out of head
Old Sep 15, 2013 | 11:54 PM
run a compression test to see how the cylinders are
remember to remove the "ecu" fuse in the engine bay to disable spark and fuel
crook803
Nov 18, 2017 04:36 PM
Dadragonlord289
Jan 25, 2015 03:17 PM
molsoncanadian
May 30, 2011 07:57 PM
bobbyjr
Nov 20, 2007 07:05 PM
nd94cx
Sep 21, 2004 07:29 PM
