1990 Honda Accord missing and dies once warmed up
Old Sep 14, 2013 | 08:54 AM
bfpicard's Avatar
Icon2 1990 Honda Accord missing and dies once warmed up
Once the car warms up it starts missing. Fixed the main relay but still has same problem. The tach starts jumping around and the car starts missing and then dies. Once this happens there's no voltage to the fuel pump. Any help would be greatly appreciated.
Thanks
Brian P
Old Sep 14, 2013 | 02:17 PM
King del Valle's Avatar
Icon6 Re: 1990 Honda Accord missing and dies once warmed up
disconnect the battery for several hours.Went you put it back and start, every thing work!? then... a Bad Sensor (transmission). Also check the temperature sensor. At this time every sensor in your Honda going Bad.
Beware about the Radio CODE if you don't have the CODE the Radio doesn't work when you reconnect the Battery.
Old Sep 15, 2013 | 12:11 AM
holmesnmanny's Avatar
Default Re: 1990 Honda Accord missing and dies once warmed up
the ignitor gives the tach its signal so start with that
crxpwr1
Aug 25, 2019 11:46 AM
Jmoreno412
Feb 11, 2019 07:11 PM
Joseph Burrough
May 7, 2017 05:29 AM
DavidKw0887
Aug 20, 2008 06:55 PM
suninmoon0
Oct 6, 2005 08:32 PM
