1992 Accord Lx F22A1 motor advice...
Old Sep 13, 2013 | 04:29 PM
doughboi904's Avatar
Default 1992 Accord Lx F22A1 motor advice...
Ok guys, I'm here for some advice from you honda gurus. About 4 months ago my bolt stripped out to my crankshaft... Rethreaded and it last for about a month and a half. Now I'm to the point where I'll just replace the crank...250$ new but people keep tellin me for like an extra 100-150$ I can get another motor for parts or even replace the one I have now(235,xxx miles). My question is which shall I do or even which motor hour I grab... I'm not trying to be all out import or fancy. Just want to get it back running to my daily driver. Not trying to spend too much.Thanks for your time and all advice welcomed.
Old Sep 14, 2013 | 12:08 AM
holmesnmanny's Avatar
Default Re: 1992 Accord Lx F22A1 motor advice...
jdm f22a
Old Sep 14, 2013 | 05:54 AM
Basic swap in and out? Anything else I have to change out?
Old Sep 14, 2013 | 11:12 PM
yes, should be direct swap
with your old engine out it might be a good time to clean out your existing intake manifold and pull the egr plugs and clean the ports
Old Sep 15, 2013 | 04:03 PM
backwood1's Avatar
I just spent a bunch of money on my f22a and it was not worth it. I finally put an f22b motor in the car. You can find them for about 500.00$. I have a oil pump and crank for the f22a it is the first undersize if that is what you decide. If you do the motor swap make sure that motor is complete intake and exhaust. You use all the mounts off your old motor they bolt up. The a/c bracket bolts up. The alt and power steering bracket have to be ground for clearance. You need to lengthen to sensor wires and make a throttle cable bracket. If you have some mechanical back round it should take about a weekend. I would consider putting new radiator in car autozone has the best price. All the hoses work along with the intake piping. .
Old Sep 15, 2013 | 04:08 PM
backwood1's Avatar
One other thing if the motor you buy has the front crank sensor on it cut the wires off so you con not see them
F22VTECyo!
Sep 14, 2016 10:36 AM
shreve66
May 30, 2016 06:33 AM
Keyaccord
32
Apr 12, 2011 02:52 PM
hometheaterman
Jul 14, 2010 09:29 AM
S1NFUL RL1 619
Feb 15, 2007 09:44 AM
