B18cr ek vibration
Old Sep 12, 2013 | 10:39 PM
Armindo's Avatar
Default B18cr ek vibration
hi everyone. i have a ek hatch just finished the swap to B18cr. the car was smooth before the engine conversion. but after swap the car feel shaking when accelerating. i have a 96 spec B18cr and gearbox. 96 spec hubs. and i have tried both dc2 and ek4 drive shaft and center shaft. the problem still there. its shaking anytime when step on the gas. especially from 20km/h to 60km/h. i have done the wheel aligment and wheel balance, swap the wheel from back to front but no luck. any idea please?
Old Sep 13, 2013 | 04:23 AM
jdmh22eg2's Avatar
Default Re: B18cr ek vibration
loose outer tie rods IE: nut not tightened to the spindle?
Old Sep 13, 2013 | 06:11 AM
bryanakabullet's Avatar
I have the same set up except 98 b18cr.
Check out the engine mounts especially the rear mount.
If not this then check to make sure there is no play in all three shafts.
but it does sound like mounts.
hope this helps
ken-e
Oct 3, 2007 10:41 AM
ken-e
Oct 2, 2007 03:06 PM
EK SQUAD 425
Mar 24, 2006 06:45 PM
fourdoorsleeper
Mar 2, 2003 07:00 PM
