1998 Honda Civic EX Temperature Guage
Old Sep 12, 2013 | 10:33 AM
bkrefting's Avatar
Default 1998 Honda Civic EX Temperature Guage
1. 1 year ago, radiator cracked - replaced
2. Fine for 3 months, driving on interstate (90 degrees outside), after 4 hours ran hot and started overheating. Pulled over, add fluid. Returned 2 days later (at night when it was cooler), no problem. Replaced thermostat. Mechanic bled system
3. Ran fine for 5 months
4. 1st long interstate drive (90 degrees outside) after 1.5 hours started overheating. Pulled over added fluid. Started overheating 2 hours later. Pulled over, added fluid. Returned next day (at night when it was cooler), no problem.
5. Replaced water pump (note vehicle does not leak any fluids during all of this time, only topped off when it was overheating). Mechanic bled system
6. Fine for 1 month, same basic scenario. Changed radiator again, bled system, checked for warped head (it wasn't).
7. This time driving in city (90 degrees), started heating up when stopped, cooled down when moving. Changed both sensors, changed to OEM thermostat.
8. Still climbs from midpoint to 3/4 point when stopped (and I assuming on long hauls, I just haven't made any yet).
So changed radiator (ex), both sensors, good head gasket, no leaks, oil fine, changed thermostat (2x), changed radiator caps (2x), all hoses are good, belts are fine, changed water pump, bled several times. WHAT COULD IT BE!
Old Sep 12, 2013 | 10:50 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 1998 Honda Civic EX Temperature Guage
Warped head/mating surfaces.
Old Sep 12, 2013 | 12:51 PM
strategy400's Avatar
Sounds like you are losing coolant somewhere.
Old Sep 12, 2013 | 01:19 PM
The Grumpiest
Probably being burned in the engine since it isn't leaking anywhere. The constant overheating has probably already killed that engine.
Old Sep 12, 2013 | 08:43 PM
Telecatster's Avatar
http://voices.yahoo.com/8-things-cau...t-7520442.html
Just a guess: Possibly a bad freeze plug with pin-hole drip. Coolant may not even leak to ground or puddle if it burns off from engine heat.
Old Sep 13, 2013 | 05:17 AM
kyden's Avatar
lol freeze plug. there isn't any.
Old Sep 13, 2013 | 06:29 AM
Where's that confounded freeze plug?
Old Sep 18, 2013 | 07:14 PM
And that is exactly why I said "Just a guess"
That confounded freeze plug is probably on that confounded bridge. Has anyone seen the bridge?
Maxcusick
Feb 27, 2018 03:36 PM
BlkAsH
Mar 15, 2016 12:52 PM
Squad1
10
Oct 18, 2009 07:24 PM
sparkrov
Feb 10, 2006 06:41 AM
migs
Dec 20, 2002 06:14 PM
