Transmission & Drivetrain Gearboxes, Differentials, Clutches
Ls cable tranny issue
Old Sep 12, 2013 | 08:19 AM
E_F_9's Avatar
Default Ls cable tranny issue
I bought a 90 Integra several months back that supposedly had a tranny problem. Well I finally got around to working on it and when I removed the tranny the pilot bearing was stuck between the clutch disk and pressure plate. After getting that sorted out I bolted everything back up but now I have a different problem. I got in the car and and push the clutch pedal down where it stayed. There was no stiffness at all to the pedal and it will only come back up if I pull it up or move the arm on the front of the tranny by hand. I also didn't think the arm should move extremely easily by hand. I pulled the tranny back off and noticed while moving the arm by hand the throwout bearing appears to be functioning normally but I could be wrong. I didn't have this problem before replacing the pilot bearing/clutch either, the pedal functioned like it should but the car was stuck in gear.
Old Sep 16, 2013 | 12:43 AM
m4xwellmurd3r's Avatar
Default Re: Ls cable tranny issue
Did you adjust the clutch yet? Theres a plastic adjustment **** on the cable bracket. You have to twist it till theres maybe an 1/8 in or so of play in the clutch arm at the cable. Basically tighten it till you can tell that the pilot bearing is resting judt off the clutch (but not touching it, you dont want it spinning 100% of the time)
Old Sep 16, 2013 | 05:35 PM
strongback's Avatar
have u changed the slave cylinder an did u bleed the clutch
Old Sep 16, 2013 | 05:38 PM
strongback's Avatar
change your clutch master cylinder an bleed it make sure there is no air in your clutch line
Old Sep 16, 2013 | 05:48 PM
strongback's Avatar
any one no about jap cvt tranny need help bad bad
Old Sep 16, 2013 | 05:53 PM
94EG8's Avatar
Seagull Management
It's a cable clutch dude.
jackinthetrunk
15
Jul 23, 2011 07:45 PM
EJ1_228
May 14, 2006 09:51 AM
teler86
Jan 24, 2006 06:30 PM
b16pwrcrx
Jun 28, 2003 11:02 AM
