Normal RPM Cutoff
Old Sep 12, 2013 | 06:46 AM
afnan's Avatar
Default Normal RPM Cutoff
Guys I have 92 accord with F18B VTEC swap with Auto Trany. The swap guys put in F23A VTEC ECU inside. Do not know why the car cuts off the RPM at 5000 RPM. My friend says that its low and even I do not have VTEC firing Up. I attached a Digital Volt Meter and Bulb too did not lit up. However I tested my VTEC Solinoid by direct Engagement it works engine sound changes. Also when VTEC is on the engine Cuts off at 3000 RPM..........Am I in ruins?
What is the normal Cutoff RPM for this car?
William5353
May 8, 2016 05:47 AM
fryman
Sep 28, 2008 02:32 PM
jeffruby
Jun 25, 2007 04:38 PM
mehheh1029
Jun 12, 2006 04:36 PM
hman09
Feb 22, 2004 08:50 AM
