IAT/AIT - Where's it located?
Air Intake Temp/Intake Air Temp - Sensor
So I've looked online(google searching), and can't find where mine is located on my N/A B16a. I get the cel code 10 AIT. Also what are these other vac line inputs/output for? One is also located behind behind the intake closest to the fire wall, not sure If the video displays it, but the other two are on the top of the intake and the other is toward the front(both black tape to block).
Here's a vid! Sorry If I don't have enough info!
Pause on the 6 second mark. On intake runner number 1 at the very top. that diamond shape casting is usually where it is located. What you will need to do is install it on the intake arm/tube since it is sealed on the intake manifold for whatever reason.
sorry to the Civic Mods. Nothing to do with all motor.
if you couldnt find where the IAT sensor is on a B16 through google, you didnt look or really try.
Hmm... I did see it was on the manifold but not mine. Was unsure where mine was since some pictures on the web were hard to see. Also mine wasn't in the location some videos/pictures were saying. Also some people are not to good at searching for stuff online/websites! Why move to Honda Accord? b16a2 engine is also in a Accord?
Thanks!
Thanks!
Since there's no place on my manifold. Is there a cold air intake out there that's iat sensor ready? Or a tutorial how to make a spot for it a cold air intake? I tried searching but can't find or I'm phrasing my words for a search wrong. Thanks!
It really simple. Drill 3 holes, one for the probe and two for the screws if its the OBD1 style that uses screws to hold it in the manifold.
For OBD2 get a PVC grommet at your autoparts store, drill a hole and do this:
Honda Parts Hero thanks! But is that for a b16a2 engine? My harness is a obd2b, so what color and location would the plug and wires be for this sensor? Do I look for a obd2b sensor since the plug might be different? Or a 2000 Honda Civic si one? I tried looking online, but again, not the best at searching! But So far some other things I've found on my own! Thanks again for replying guys!
apparently this is my sensor... http://www.oreillyauto.com/site/c/se...vic&vi=1363025
Nice_Dc2r
May 26, 2003 03:44 PM
