Rear Engine Mount
Hi
I have 92 accord in which F18B has been installed. The car has vibration inside car. I have already changed front, Left and Right Mounts. Now its better but still too much vibration. The car is equally vibration free when in Reverse gear.
But if you put the car in Drive the car is nightmare. It vibrates like hell. My friend told me that when car is in drive the most load shifts to rear mount. I opened the air cleaner and took best possible picture. I do not know what is the good condition mount or is this vacum mount or oil based mount. If you can suggest me something i can do even if i have to apply different mount i can do that if i have figure.
Thanks
Thanks
Judging from the debris it appears busted. To be sure, carefully slide under the front of the engine(at the radiator, no more) and grab the oil pan and try to wiggle front to back. The engine should not move at all. If it moves the mount is busted.
