best cams for b20vtec?
i just messed up my buddy club spec3 cams
now i need new ones i need ur guys help for best fit for my build iam using a b20z2 block high compression pistons 0.50 with Ls crank
i just rebuild my gsr head this is what i done so far
new valve job,surface,valve guides,double springs and retainers optomi power,new ferrea valves,new skunk2 lost motion assemblies, supertech valve stem seals, new rocker arms,550 rc injectors,aem fuel regulator,obx throttle body,golden eagle cam gears, now i need some cams that will make best hp gain with my build.
There is no such thing as best. If you want the best - buy them all, test them, and go with which one does best for you.
If you don't want to do that, then look through the dyno thread and see what people have had success with.
Is this a daily driver? What are your goals? Really hard to make a recommendation based on the info given. What's 'high compression'? Is there head work? TB size? Port matching?
That being said..
The Pro1 cam by Skunk is a continuously proven performer in motor's like yours.
Anything with a Jun 3 VTEC lobe will produce good results as well, depending on your rev limit and setup it will beat the Pro1 on the high lobe.
I'd look into the Skunk Pro 1s, Blox type C, or Buddy Club IVs for that setup probably.
That being said..
OP Whats the overall goals of the setup, Use? and powerband needs. There's plenty of cams on the market, that will fit the needs that you may be after.
[QUOTE=DDTECH;49134071]
Thanks for the support brother.
OP Whats the overall goals of the setup, Use? and powerband needs. There's plenty of cams on the market, that will fit the needs that you may be after.[/QUOT
with my current build my dyno results are max power 180.40 to the weels 133.34 max torque with stock piping n/a and thats with my buddy club spec3 cams head was stock before now is build with all those parts i mention now im looking for something will be better for my head
I would also ask the question, "what is the best IM"
Cams and IM work as a combo. Cams open and close valves, and based on how much momentum the air has (largely determined by IM) will determine your power and power band.
Get the combo right, and you'll be ballin
Everything needs to work as a combo. It all needs to be balanced. The cams, intake manifold, throttle body, intake size and length, etc. etc. All about balance.
Do you really think half of these people would even think about that or even understand that not one component/part on its own will make power,there needs to be a selected group of components/parts that all work together to make power and then think seriously about the rest of the cars setup if it will support the engine built using the assembled components/parts that make a great engine.
I know, i, just making a suggestion. I think that manifold can benefit no matter the cam selection and would help the cam and motor breathe better(for a street motor/daily driver).
InTeGrA GsR 321
Oct 16, 2005 10:06 PM
