Allmotorryan's 96 Gsr Sedan
I was 18, just sold my h22 swapped dc4 and was looking for a gsr sedan. they have always been my favorite since I saw one at the 2008 Marcus dairy car show that my brother brought me to, I was raised on muscle cars and imports were a new concept to me so I knew nothing about them clearly because my first car was a shitbox the best advice i ever got was from allmotordan now know as shgdan he told me go buy a bone stock car and build it how you want to use it. so On August 17th 2010 I drove past a green integra 4dr and i noticed it had special edition wheels on it so I figured eh why not ill take a look I walk up to it this thing is clean mint paint all original one owner women driven and I instantly fall in love with it then I sit in it and notice the redline is at 8,000rpm and my eyes lit up I ran to the back and saw the Dohc vtec badge then poped the hood, it was a gsr I instantly wanted it the guy was only asking $1,900 but it had 220,000miles then I remembered its a honda and he happened to mention he was the only owner so I asked him how much he would go down to he told me $1,400 and it was sold to me, I have had the car for 3 years now and I've improved and made mistakes while building this car, the one thing I have learned is quality parts are a must, and nothing beats oem quality. Here's some pictures of it through the last 2 years and where I'm at now in the middle of a full restoration.
Goals: comfortable street drive able car 350-400whp that can get 25+ mpg smoke some bolt on mustangs wrx's ect and go to any track and be competitive.
Mod list.
Motor:
9:1 Je pistons
Eagle rods
Arp head studs
Gsr head
Super tech flat face valves
Super tech dual valve springs and ti retainers
Garrett 60trim
Full race ram horn manifold
Tial 44mm wastegate
Greddy 38mm bov
Precision 600hp intercooler
2.5in SRE intercooler piping
Jdm type r throttle body
Skunk2 gen 1 intake manifold
Idi1000 injectors
255 Walboro pump
Hondata s300
Apexi ws2
Vw golf dual core fullsize radiator
Interior
Itr non srs wheel
Gsr cloth seats
Type r radio block off
Suspension:
F&f type 1 coil overs hopefully be replaced by AMR or PIC coils
Hardrace replacement bushings.
Fullrace traction bar
22mm itr rear sway bar
Asr black subframe brace
Body:
Pwjdm 3 pt front strut brace
Pwjdm rear 4pt strut brace
Rpf1's 15x7 +35
225/45/15 Bfg Rivals
4door type r rear bumper support
When it got home.
First thing I did was clean the engine bay and lower it on h&r springs, it all went kinda downhill from here.
Here's a summary in pictures
Mod list.
Motor:
9:1 Je pistons
Eagle rods
Arp head studs
Gsr head
Garrett 60trim
Tial 44mm wastegate
Greddy 38mm bov
Idi1000 injectors
255 Walboro pump
Hondata s300
Apexi ws2
Interior
Itr non srs wheel
Gsr cloth seats
Suspension:
Body:
Rpf1's 15x7 +35
When it got home.
I bent the valves in my freshly rebuilt motor and decided it was time to take the whole car apart and rebuild it how it should be done. The body was just starting to rust and I won't deal with that so it was time to see how bad it really was
Rear bumper was shot and trunk was starting to rust from water sitting in it so I setup a work area and got to work.
The sealer and paint I'm using is por15's rust products I will be using it on pretty much everything I then proceeded to do the rear end and work my way up to the front wheel wells
I used alot of oem plugs from a parts car to plug up many of the open holes in the wheel wells from abs sensors and whatever else was there.
Here's alittle update got to work this weekend
Started sanding under here
Got the tank out and decided to restore it
I got this part done first alot of sanding and prep done on this should last me another 17 years hopefully lol
Some more prep work just scuffing things up and getting rid of surface rust
After about 4hours under the car and inside I decided it was time to get some paint on it
I also got these in waiting on some more parts and I can start to reassemble the rear end ill be working my way up to the front now
Been slacking on the updates
Motor is off to get fixed, most of the rest of the car has been put back together taking my time and making everything perfect.
So just a little progress before winter hit, sold some of the turbo parts and bought the wheels and tires I've been wanting, motor is at my brothers work gunna be putting fresh bearings in and getting the head cleaned up over the winter hopfully I'll be on the track in August, I won't be turbo just yet but running and driving is a plus, getting closer to it. Now I just need spring time and some camber adjustment, hoping to keep it around 2* out front and 1.5* out back might need to roll my fenders tho.
JOSEPH
Oct 29, 2009 12:36 PM
