need some help with putting 90s in collector
Old Sep 10, 2013 | 11:18 AM
hoochhenry's Avatar
Default need some help with putting 90s in collector
looking to make a collector starting with all 90 bends from turbo flange wat sort of angles do i need to cut them to make all 4 fit ,onto a t3 flage something like his collector but with 4 90s bends
Old Sep 10, 2013 | 02:02 PM
SovXietday's Avatar
Default Re: need some help with putting 90s in collector
The same as if you were doing it with straight tube, but you will need to make the cuts according to where the 90 needs to point.
Also would tell you to be damn careful, because if you're not you'll end up screwing yourself out of being able to weld sections real easily.
Old Sep 10, 2013 | 11:34 PM
hoochhenry's Avatar
il give it a try on some pvc bends today thank you
Old Sep 11, 2013 | 04:38 PM
para pat's Avatar
I first figured out my flange opening width, and split the difference between the left/right 90s. Then I picked the intersection angle, and then took the flange depth, and split the difference between front/back 90's. Then welded it all together. Yes, it's very tight but not impossible to weld.
Old Sep 12, 2013 | 12:16 PM
hoochhenry's Avatar
very nice but the welding must be thight as hell to do lol ,,,any more pics of some others ?
lsvtechatch92
Welding / Fabrication
29
Dec 8, 2007 06:51 AM
got wide
Aug 2, 2007 01:39 PM
booosting23
Apr 28, 2006 10:28 AM
muskrat hatch
Jan 18, 2006 09:39 AM
mike1114
May 2, 2003 03:01 PM
