B18c running rich issues
Old Sep 9, 2013 | 09:09 PM
ekcivic2's Avatar
Default B18c running rich issues
Hi,i am experiencing a very bad gas mileage with my b18c4,i have changed several basic parts like,msd coil,new cap and rotor,new spark plugs,map sensor,tps,iat,ect but still running poorly on low rpm.I even scanned the ecu recently,no sensor faults were found,the o2 sensor voltage varies from 0.1-0.9 at idle,it keeps fluctuating,i don't know if its normal.
Engine specs b18c4,ITR ecu,b16b cams,skunk2 intake manifold.
If anyone can suggest me the what could be done to solve this problem,it would be much appreciated,thank you.
Old Sep 14, 2013 | 08:07 AM
ekcivic2's Avatar
Default Re: B18c running rich issues
Well we discover that valve clearance was out of specification IN 0.007'' and EX 0.012'' and according to manual it is supposed IN 0.007'' and EX 0.008''.So we adjust it to the correct specification and now the engine is less noisy and it consumes less gas but engine response has reduced.Is that normal?
Old Sep 14, 2013 | 07:08 PM
EsotericImage's Avatar
Retired Moderator
as long as everything is in spec and no codes are shown, you are good to go
96blk_vr
Jan 30, 2014 10:13 AM
D7KWagon
Nov 15, 2013 12:03 PM
a12rnulfo
Jun 11, 2006 08:01 AM
jdmtim
Jan 26, 2003 10:58 AM
civicracer1993
Aug 27, 2002 06:50 PM
