RED 99 EK clean title/5 lug/and more
Selling my 1999 civic hatchback. Clean title, NOT SALVAGE!
no test drives unless you come with cash!
if you have any questions call/text me at 682 521 5 nine four 5
A/C and P/S works
This car runs and pulls hard
it doesnt smoke but it does eat some oil
******i am asking 6500 OBO******
******NO trades cash only*******
I only have a few pics, but should be getting more this weekend
Parts for sale
CTR Milano red thin side moldings 200
CTR Milano red CTR mirrors with harness. PLUG and PLAY 300
OEM SI lip with ALL the accessories 200
NEW CF CTR Spoiler, NEVER mounted 260
NEW OEM 99-00 front bumper still wrapped up 140.00
NEW OEM 96-00 Rear bumper still wrapped up 140.00
if you want pics here is the link
http://hondamarketplace.com/showthread.php?t=3167105
INTERIOR
OEM si cluster that reads 140,927
red Recaros, with a cig hole on the driver side
power windows/locks
ALARM
Viper 5904 alarm system
There is about 14x,xxx miles on the chassis
there is 104,427 miles on the motor
BODY
CF hood, not sure of the brand but it does need clear coat on it
Honda OEM window visors, it does need clear coat on it as well
there are dings and what not on the body, 5/10 rating
front bumper has scratches on it and also fog light holes that are cut out already
(i have a new OEM front bumper if you want to purchase it)
rear bumper has a small crack underneath passenger light
(i have a new OEM rear bumper if you want to purchase it)
SUSPENSION
5 lug conversion
OEM itr white rims w/ falken tires.
power slot rotors, slotted rotors
OEM honda brake pads
Tien Flex Coilovers - they ride nice!
CTR 1" brake booster
AUDIO
Alpine CDA 9885
infinity 6x9
not sure what i have in the front
MOTOR
GSR OBD1, dropped in my car at 90k miles
password JDM CF whale ***** intake
Mishimoto Radiator with cap
Supertech Titanium Valvesprings
Supertech Titanium Retainers
Blox Type B cams
SkunSkunk2 Pro Series Intake Manifold (Portmatched to Throttlebody)
Professional Products 65MM TB (Polished)
RC310cc Injectors
Outlaw Engineering Full Intake Gasket Kit (Intake Manifold/Throttlebody/IACV/Extended Studs and Bolts)
Gates Carbon Timing Belt
Skunk2 Cam Gear (Intake side)
ITR Throttle Bracket
when the motor was swapped in these parts were installed
New OEM Oil Pump
New OEM Oil Pickup Gasket
New FelPro Oil Pan Gasket
New OEM Cam Seals
New OEM Waterpump
New OEM Timing Belt Tensioner
New Distributor Cap
New Distributor Rotor
I also just bought a new battery
new spark plugs
new NGK blue spark plug wires rotors/cap
Transmission
at the time of the swap it had 45k miles on it; it now has 59,427 miles on it
USDM ITR Transmission w/LSD
xACT 12lb Flywheel
Exedy Stage 1 Clutch
before the transmission was swapped in these parts were installed
New Syncrotech Carbon Coated Syncros
New Bearings
New Seals (Differential and Input Shaft)
New Mainshaft (New 1st & 2nd Gears)
New Hub Springs
New 5th/Rev Hub and Collar
New LS 5th Gear (Mainshaft and Countershaft)
New Slave Cylinder
Engine Management
Honda s300
P06 chipped ECU
tuned by Seth at Trackstar in arlington, it made 175 HP
Exhaust
Greddy headers
WS2 Full catback
that black spot on the top of the seat is not a hole, its just the pic
A/C and P/S works
Parts for sale
INTERIOR
power windows/locks
ALARM
BODY
SUSPENSION
5 lug conversion
AUDIO
Alpine CDA 9885
infinity 6x9
MOTOR
Blox Type B cams
RC310cc Injectors
New OEM Oil Pump
New OEM Cam Seals
New OEM Waterpump
New Distributor Cap
new spark plugs
Transmission
xACT 12lb Flywheel
New Bearings
New Hub Springs
New Slave Cylinder
Engine Management
Honda s300
P06 chipped ECU
Exhaust
Greddy headers
WS2 Full catback
E46Kid
May 11, 2010 01:56 PM
