what bulbs in 94 ls cluster and how do I adjust headlights
The big bulbs in the cluster are 168 or 194. I've used both sizes before and there should be 3 of those. All the tiny ones, I believe you can buy them at radio shack, well that's what I did with my old rsx. Google the adjusting headlight. Im sure there's plenty of info out there but if its aftermarket halo ****, good luck bc I had those back in the days and the beams were off permanently no matter how much u adjust
Its been a while since I've had stock headlights but I believe there is an adjustment screw near the outer upper corner of the back of the housing. It would be a Phillips head. hope that helps. alternatively aftermarket headlamps run about $120 and also have ones with projector low beams and angel eye leds. there is a big *** on the back of these for the adjustment.
