Steering wheel shaking and vibrating... Not tire balance?
Old Sep 9, 2013 | 06:08 PM
apbtwhiskey's Avatar
Default Steering wheel shaking and vibrating... Not tire balance?
So i drove to get my new rims and tires put on today... Drove there on my little 14 inch steelies with shitty tires fine... I got my new rims and tires put on and got vibrations and steering wheel at about 40 or so and 75ish as well... Could this be a bad tie rod? Ball joint?
Old Sep 9, 2013 | 06:44 PM
mike205's Avatar
Default Re: Steering wheel shaking and vibrating... Not tire balance?
Probly not
It's most likely the tires or wheels
Did they road force them? If not drive it for a little bit then get them rebalanced
Old Sep 9, 2013 | 06:50 PM
road force them?
Old Sep 9, 2013 | 09:04 PM
Tyson's Avatar
I think your tie rods and ball joints and steering rack all need to be looked at for sure.
It may not be the exact reason for the shake, but it certainly wouldn't hurt to start to look at them and replace as needed.
When you have vibrations, it wears everything else out.
Old Sep 10, 2013 | 02:43 AM
rotenkid's Avatar
I had the same thing awhile back and my lugs were coming loose.
Old Sep 10, 2013 | 02:56 AM
Freemananana's Avatar
I have 2 lugs come off a car previously. Thank goodness it was a drum brake. It bent the rim and it was a bad day. But I survived.
I had vibration on my car and it was my wheel nuts being loose. The part that holds the axle to the knuckle. 134 ft-lbs if you are going to tighten them to spec. That solved my issue mostly.
Old Sep 10, 2013 | 05:34 AM
dopesincetime's Avatar
check your drive shafts. I was having similar problems until I changed both sides.
Old Sep 11, 2013 | 11:21 AM
SlowCRXHF's Avatar
I would have them rebalanced elsewhere to ensure they were done correctly.
Old Sep 11, 2013 | 12:51 PM
Not to high jack the thread entirely, but I am having similar symptoms it seems. At 35+ mph the steering wheel on my car shakes a little bit. But it shakes a little less when I push in the clutch and I'm not putting power to the wheels.
Having similar symptoms OP? Or is it just a shutter at 40 and again at 70 then it goes away? Do you have a motor swap? Or is it stock?
Old Sep 11, 2013 | 04:26 PM
Rob.'s Avatar
Worn motor mounts can cause this because it will make the driveshafts vibrate.
Could also be worn shocks.
People always assume it's unbalanced tires/wheels !
Old Sep 11, 2013 | 04:42 PM
4drEF's Avatar
Keyboard Humorist
Wow... some non-readers here.
Guy had perfectly fine ride on his 14s.
He goes to a shop and gets new wheels put on and right then the vibrations start.
And you want to suggest shocks, motor mounts, driveshafts (lol! must be an s2k!), axle nuts, etc.
.... reaaaalllyyy....
Old Sep 11, 2013 | 05:33 PM
Tyson's Avatar
i agree.
i didnt read thru the OP carefully.
just go back and have the tires rebalanced.
Old Sep 11, 2013 | 06:08 PM
AdrianClayton's Avatar
Before you do anything, If you own a torque wrench, check your lug nuts. Spec is 80ft Lbs but I go 100 to be safe.
Old Sep 12, 2013 | 03:00 AM
True true. I suggested the axle nuts because it happened to me in the past. But it should be the tires being unbalanced.
And by driveshafts I think they meant CV axles.
Old Sep 14, 2013 | 01:49 PM
Ok yes i do have a torque wrench so i will torque them down... 134lbs? seems like a lot i was thinking like 80lbs... the car does have a swap obd0 b16 with gsr trans
Old Sep 14, 2013 | 01:50 PM
Should i take the wheels off before i retorque? maybe they arent sitting right?
Old Sep 14, 2013 | 01:52 PM
and just in case anyone was wondering the rims are 949racing 6uls and tires are hankooks (not the best tires but way better than the shitty tires on my steelies which is why im stumped)
Old Sep 14, 2013 | 04:16 PM
Tyson's Avatar
This is really stupid advice. Don't follow this.
Old Sep 15, 2013 | 06:34 PM
you can take them off if you want or just check if they are tight, torque to 80 ft lbs regardless
I said this because the program i use for looking up spec says 80 - 100 so that would mean you can use anywhere in between would it not?
Old Sep 16, 2013 | 12:16 AM
Tyson's Avatar
the factory service manual says 80 ft lbs.
over torquing a bolt over 20% is not being "safe" or smart.
Old Sep 16, 2013 | 02:47 AM
Okay, insults done. 80 ft/lbs is for the lug nuts right? I was saying 134 ft/lbs for the axle nut. And that seemed low to me.
Old Sep 16, 2013 | 05:27 AM
Spug's Avatar
Yes, 80 ft-lbs for the lug nuts.
sd619jef9
Nov 5, 2011 10:14 PM
bsmith100
Mar 10, 2010 01:10 PM
SPOOLINmatt
May 29, 2008 11:16 PM
Baron55
Jan 2, 2007 12:48 PM
Nizzy
Aug 21, 2003 07:31 AM
