Simple wiring question
Old Sep 9, 2013 | 02:52 PM
twenz's Avatar
Default Simple wiring question
My son just bought a 1997 Accord LX. Radiator fans and AC not working. Through much trial and error I discovered that the radiator fan timer control located behind glove box was not plugged into its wiring harness. The radiator fans now work - yeah!! Someone must have unplugged them when perhaps replacing the 4-speed fan control module and forgot to reconnect??.
My question though, another 2-pin connector is hanging loose from the same wiring harness and I cannot see anywhere behind the glove box where it might get plugged in. The connector is blue and has a red and a green wire attached to it. Does anyone know where this get's plugged in and what its purpose is? Any chance it might be related to why the AC does not work?
P.S. Compressor fired right up when I jumped the relay.
Old Sep 9, 2013 | 03:19 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Simple wiring question
The blue connector is the Service Check Connector (SCS). You can use it to retrieve Diagnostic Trouble Codes (DTCs) by using a wire or small paper clip to jump the connector and counting blinks of the Check Engine Light and/or D4 indicator light for automatic transmission.
The 1997 has both the OBD-II port (behind the ashtray) and this separate SCS connector.
DominusOne
Jan 3, 2014 01:18 PM
HellaStockEJ6
Oct 28, 2013 08:53 PM
fireant
Apr 19, 2008 09:54 PM
EnjoyTheRideDC2
Mar 24, 2005 03:56 PM
