Cruise Control is not working
Old Sep 9, 2013 | 10:54 AM
Zac W.'s Avatar
Default Cruise Control is not working
Long story short....when I bought my 99 LS, the previous guy removed the CC unit from under the hood and the foot pedal bracket that attaches to the cable. So, I bought the bracket and unit from a donor car thinking I would have instant CC. Well, I'm not an electrician or an auto mechanic so I need your guys help. I tested for power at the plug at the CC unit under the hood and I have no power. Checked fuses and they tested good. The push button in the car lights up when depressed letting me know its working (assuming). I guess I need to know what to check next. All of the other CC components are present under the dash, left of the clutch pedal. Thanks for any help.
Old Sep 9, 2013 | 11:03 AM
kyden's Avatar
Default Re: Cruise Control is not working
do you have the clutch switch in?
Old Sep 9, 2013 | 04:20 PM
Zac W.'s Avatar
Yes
Old Sep 9, 2013 | 04:39 PM
Zac W.'s Avatar
Ok.....I've been doing some reading. The switch is there but it must be bypassed because I can start my car without engaging the clutch. It sounds like I need to fix that first.
Old Sep 10, 2013 | 05:02 AM
kyden's Avatar
it's not the same. you have 2 switches. 1 is for cruise control, 1 is for the starter.
Old Sep 10, 2013 | 06:43 AM
fcm's Avatar
fcm
Old Fart
That will be your problem, or one of them, the switch is used to signal the CC unit if the clutch is pressed so CC is disengaged, if the CIS is jumped the CC "sees" it as always disengaged. 94
Old Sep 10, 2013 | 07:49 AM
Satchel_Charge's Avatar
My car starts without the clutch (PO's doing, claims he grounded the switch) yet cruise control works fine.
Old Sep 10, 2013 | 01:36 PM
fcm's Avatar
fcm
Old Fart
It depends on how the switch is bypassed.
The CIS is grounded on the input, [black] it supplies a ground, [blue/black] to the starter relay, when clutch stepped on.
The CIS on cars with CC have a 2nd output, [pink] that supplies a ground to the CC unit as long as clutch is not stepped on, if you ground the blue/black the engine will start but it has no effect on the CC, or if both the blue/black and pink are grounded both starting and CC would work but you lose the "safety" of disengaging the CC if/when you step on the clutch. 94
Old Sep 10, 2013 | 02:19 PM
Good info.
Old Sep 10, 2013 | 04:16 PM
Zac W.'s Avatar
Very good info! Give me a few days. I have to work 12s until Friday. I'll do some investigating then report back as to what I found.
Old Sep 11, 2013 | 06:49 AM
kyden's Avatar
there's two switches on the pedal. The pink wire is at the lower switch, which only controls the cruise. The switch at the top is the one used for starting. Not sure why anyone would touch the lower switch at all, as the circuits are separate from each other.
Old Sep 12, 2013 | 07:05 AM
fcm's Avatar
fcm
Old Fart
Your right, on the 99 Integra it was two switches, however the result would be the same if both were grounded, and why anyone would touch the lower on, is the same reason they would touch the upper one, stupidity. 94
Old Sep 12, 2013 | 09:43 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
CIS switches are commonly bypassed in order to install remote start on a car with manual gearbox. Most pro installers worth a damn won't do it, but many lower-end installers and DIY'ers do it.
I can also confirm the existence of 2 switches on OBD1 G3 cars, with no relationship between the circuits of either switch, except that they both send the ground signal to the same body ground point. The CIS is normally closed (circuit closed when clutch is depressed, which releases the switch and closes the starting circuit), while the CC switch is normally open (circuit opens when clutch is depressed, which releases the switch and opens the circuit).
Auxient
Apr 1, 2018 07:50 AM
bnewall1
Nov 19, 2013 12:01 AM
ed6inms
Nov 24, 2012 12:43 AM
moorevisual
14
Jun 28, 2011 06:58 PM
Dezmon
Mar 9, 2007 06:38 AM
