Stock GSR Idle and operating problem
Old Sep 9, 2013 | 09:57 AM
KidRuthless's Avatar
Post Stock GSR Idle and operating problem
Okay so I have stock 1998 Gsr in a 1997 dx (ek) hatchback with a blox intake manifold, running on a chipped p28. So the problem lately is when driving my car it will jerk like its cutting out then stop and drive normal. Just the other day it started the same problem then the car shut off and the check engine light came on when I tried to retrieve the code it stayed solid and wouldn't blink like it should to give me a code. When I had the jerking problem a few months ago I replaced the dizzy and it stopped for awhile now its coming back difference is the car shutoffs when driving. PLEASEEEE HELP
Old Sep 9, 2013 | 01:52 PM
B_Swapped93's Avatar
Default Re: Stock GSR Idle and operating problem
Sounds like a bad TPS sensor check it for dead sports.
Old Sep 9, 2013 | 07:57 PM
Okay I just pulled my harness out going to rewire then Ill check the TPS sensor good looking out B Swapped93
Old Sep 10, 2013 | 01:26 AM
HondaPartsHero's Avatar
Technical Hero
Also check your ecu for any burnt spots on the circuitry.
SlickEJ8
Sep 16, 2010 01:44 PM
ungcobob
Jan 18, 2007 11:54 AM
Catman316
15
Apr 14, 2005 03:31 PM
Catman316
Mar 21, 2005 07:51 PM
AllMotor12s
Mar 11, 2004 08:42 PM
