90 accord help
Old Sep 8, 2013 | 10:45 PM
camry-man's Avatar
Default 90 accord help
So my 90 accord f22a1 with px4b.
Just replaced transmission now its haveing some problems start car put in drive car acceleration is great till second gear then slows way down I can put the gas peddle to the floor and nothing rpms dont even go up. Then I come to a complete stop and it accelerates great. Have no clue whats going on so any help and yes all my fluids are full prim converter. Talked to a few people one said it could be my fuel filter but not sure. So any help
Also if I put it on stands with no load I have non of these problems shifts into all gears and no loss of rpms and no problems. Could this possibly my torque converter. Cause symptoms only happen when a load is on the vehicle. Just a thought
Old Sep 10, 2013 | 04:56 PM
Lost Again's Avatar
Default Re: 90 accord help
WTH.....any stored codes?
Ground on the t-stat housing is clean and tight?
Was this there "before" the trans change?
Old Sep 17, 2013 | 10:52 PM
camry-man's Avatar
Ground is fine.
Not sure with codes always seem to **** them up some how counts off or just dosent come out right.
Problem with the old trans was massive slipping not shifting properly and wouldnt go over 43mph also cracked casings.
Old Sep 17, 2013 | 11:29 PM
holmesnmanny's Avatar
check your kickdown cable it may need to be adjusted
Old Sep 18, 2013 | 08:33 PM
camry-man's Avatar
Will do in the morning then I will see what happens
debbie49
Nov 12, 2010 03:58 PM
mark28269
Apr 14, 2008 07:09 PM
