2000 Accord V6 idle issues
Old Sep 8, 2013 | 02:17 PM
nrmskate's Avatar
Default 2000 Accord V6 idle issues
My accord has a high idle 95% of the time, every once in a while it will go back down to normal, but that's rare. Sometimes the idle fluctuates like the IACV is bad or dirty, but I've cleaned it twice now. The idle is high no matter what, hot, cold, or at N.O.T. I took it to a good reputable mechanic and he told me that it was the intake manifold gasket, so I replaced both of them today. Car seemed to idle fine, then I took it on a drive and it started doing the same thing. If I put it in neutral and rev the engine to 5-5500 rpm and let it drop, the idle will go back to normal. Please, tell me somebody has a friggin clue what this is. I cleaned the intake plenum and EGR port when I had the manifold off as well. No dice. Any help is appreciated, thanks!
Old Sep 9, 2013 | 05:25 AM
nrmskate's Avatar
Default Re: 2000 Accord V6 idle issues
$20 paypal'd to whoever has the correct solution for this problem
Old Sep 9, 2013 | 09:46 AM
Keith Coles's Avatar
Not totally sure but I had a similar problem with a V6 Vectra. Turned out to be the idle control valve (or IAC valve as its sometimes known) removed and cleaned it and my idle issues went away. May be worth a google?
Old Sep 9, 2013 | 09:51 AM
nrmskate's Avatar
If you read, i've cleaned it twice and still no dice.
Old Sep 10, 2013 | 08:28 AM
Lost Again's Avatar
Just for giggles, let it re-learn idle.
Cool/cold engine. Pull the cables to clear the ecu/pcm. Connect it back up. Start the car with no engine load (ac, blower, radio, ect in the off position) and DO NOT touch the throttle. Let it sit there and run until the cooling fans cycle at least once. Cost to you is nothing but a small amount of time.
rockycat
Feb 19, 2015 05:59 PM
genopian
Jul 23, 2014 06:45 PM
steelhitman1245
Nov 16, 2011 06:51 PM
sun_zinc
Jul 13, 2008 01:19 PM
mrpickyman
Nov 2, 2002 05:22 PM
