ls throttle cable on gsr tb
Old Sep 7, 2013 | 04:33 PM
bmoreb18c1's Avatar
Default ls throttle cable on gsr tb
the bolt hole castings on my throttle body for my throttle cable bracket got broken today and I've been trying to find a quick solution to be able to have car running for work Monday. I keep seeing people say use the type r bracket but that will be a couple days from the dealer, I have a s2 IM which has bracket holes for the other type of cable bracket and I can't seem to find out if a. The ls bracket will work even if I have to modify it and b. Will a ls cable work with just changing out the pulley and adding bracket. Thanks for any and all help in advance
Old Sep 7, 2013 | 05:29 PM
B_Swapped93's Avatar
Default Re: ls throttle cable on gsr tb
What manifold is currently on the car 2nd with an ls tb all you'll need is the braket and cable and you're set a gsr cable will nit work.
Old Sep 7, 2013 | 07:07 PM
bmoreb18c1's Avatar
My car is a 01 gsr with a skunk 2 IM. Can I still use gsr tb and just swap the pulley and cable or do I need the whole tb
Old Sep 7, 2013 | 07:14 PM
pulley, cable and bracket are needed you can use which ever TB you like.
Old Sep 7, 2013 | 08:04 PM
bmoreb18c1's Avatar
Thank you, I feel much better about the situation
Old Sep 10, 2013 | 01:41 AM
bmoreb18c1's Avatar
So I now know why the other forums say you need type r bracket. Because the ls bracket is in way of sensor
cibao2ner
11
Oct 13, 2011 03:20 PM
ekBrad
Jul 22, 2009 01:52 PM
admess188
Apr 12, 2007 03:47 AM
AlxSiR7
Jun 1, 2005 08:55 PM
