Can you guys help me identify this leak?
Old Sep 7, 2013 | 01:42 PM
Pancho2193's Avatar
Default Can you guys help me identify this leak?
The leak is coming from under that little cylinder shaped object. where I'm pointing to with the extension. Any idea where that could be coming from?
Old Sep 7, 2013 | 02:47 PM
B_Swapped93's Avatar
Default Re: Can you guys help me identify this leak?
get some brake clean and wipe the are down, having a hard time thinking what is there other then the water pump is it an oil or coolant leak ?.
Old Sep 7, 2013 | 02:59 PM
Pancho2193's Avatar
It's an oil leak, and yeah when the car was put together I Degreased the entire underside and sat under the car while it was running for a couple of minutes and traced it directly out of that crack where that little cylinder thing meets the block.
Old Sep 7, 2013 | 03:18 PM
can you get the camera down in there all I'm seeing is the whole for the water pump.
Old Sep 7, 2013 | 03:22 PM
jdmjunkieXL's Avatar
Are the bolts tight??? There is an oring right there right behind where ur pointing too
Old Sep 7, 2013 | 04:42 PM
wayneDOHC's Avatar
head gasket? back right (when facing the car) corner of the head. its hard to tell with these pics.
Old Sep 7, 2013 | 05:03 PM
slomofo's Avatar
GDD Member
Only thing there I can think of is the head gasket or the unlikely chance that you've got a traveling valve cover leak.
Sent from my Motorola startac using IB AutoGroup
Old Sep 7, 2013 | 06:25 PM
Pancho2193's Avatar
I did have a blown head gasket, hence the head taken off, but that leak is coming directly from where I'm pointing at in the first picture. thats where the leaks start
Old Sep 7, 2013 | 06:45 PM
wait wait ! is this not where the water pump goes(circled in yellow) ? or am I looking at it wrong. The pump is on the block so it wouldn't be coming from the head and in-between the block(if i'm looking at it right). Can you clear it and take a better pic with the camera down at the level of the leak ?
Old Sep 7, 2013 | 06:54 PM
Hes pointing to the oil pump like i said in my previous post there is an oring behind the oil pump right there that meets the block surface i usually silocone the block and pump mating surface and silocone the outer part of the oring wen its in its place in the pump just in case
Old Sep 7, 2013 | 07:03 PM
now I feel dumb ! lol damn I forgot how big it was. As stated then are all the bolts tight(to spec). 2nd guess I would say Is the gasket is starting to go. what I would do as a temporary fix is dab some RTV sealer around the area.
Old Sep 7, 2013 | 07:13 PM
yea ur almost there i would just take the pump off first inspect pump per repair manual clean the surafces and replace oring and re silicone the pump
higgy1
Honda Civic (2001 - 2005)
Jan 4, 2017 06:30 AM
adio8352
May 2, 2011 08:03 PM
xation
Aug 18, 2007 02:41 PM
SPORT INJECTION
Aug 25, 2003 12:15 PM
RS1995
Apr 7, 2002 09:21 PM
