F22b1 wont rev past 3,500
Old Sep 6, 2013 | 09:32 PM
Jtkdirtbike's Avatar
Default F22b1 wont rev past 3,500
I just pulled the motor to relocate break lines and now when I start it rpms wont go past 3500 and it sounds like a rev limiter... Its throwing codes 41 (heated O2 sensor) and 4 (crank shaft position sensor) code 41 is something I normally drive with so I dont believe that could be the problem and Code 4 is new this motor is from a 1994 accord ex and is obd1 so I dont believe it even has the ckp crank postion sensor Let me know if youve got any ideas
Thanks
Old Sep 6, 2013 | 09:36 PM
Default Re: F22b1 wont rev past 3,500
I will be checking the distributor for connection issues in the morning incase the ckp is located there
Old Sep 7, 2013 | 04:59 AM
holmesnmanny's Avatar
its in the dizzy...see if connector partially unplugged
Posted from Honda-tech.com App for Android
Old Sep 7, 2013 | 10:22 AM
I can see exposed wire going into the distributor so I will check for continuity between the plug and the wire inside the distributor as well as between all the wires to make sure their is no short.. hopefully that fixes it. maybe the sensor itself i bad
Old Sep 7, 2013 | 06:47 PM
Popped of the distributor cap and sure enough one of the wires to the ckp broke... Thanks
Rhood
39
Apr 6, 2017 10:03 AM
accordcrx
Nov 24, 2005 02:03 PM
YellowR2000x2
Mar 4, 2005 04:29 PM
powerLINEinteg
May 6, 2003 07:57 AM
B16pwrHB
10
Sep 21, 2002 02:59 PM
