boostlsveg street/drag eg build
Old Sep 5, 2013 | 06:27 PM
boostlsveg's Avatar
Default boostlsveg street/drag eg build
hi guys my name is mike I been in the hobby about ten years now. Ive had this car since around 2006 and it was my second honda. So it started off an ls vtec with about 200whp in 2006-2008. In 2008 the timing belt snapped on me and I bent a couple valves and I had just lost my license so it had to sit. Two weeks before that happened I just got new wheels, drilled and slotted rotors, pads, coilovers, lcas, traction bars, balljoints , tie rods, and wheel bearings. Its sat until now lol but its getting closer to getting back on the road. She is a 1992 cx hatchback it is red with black roof, hood and hatch right now but will be painted shortly probably black cherry metallic and I might stick with the old theme and do the roof and stuff black, not sure on that yet tho. Now for the new setup:
Block: 99 GSR block
Golden Eagle Sleeved and o-ringed
Micro polished and Balanced LS crank
Manley Turbo-tuff I-beam LS rods w/ arp 2000 rod bolts
JE pistons (T1 custom) 84.5mm ~9.4 cr
It was assembled with all OEM honda bearings (PINK)
OEM GSR/TypeR oil and water pump
OEM GSR timing belt
Head: ITR head currently in the machine shop getting new seals, bronze guides, and a valve job.
supertech flat face nitride coated valves std size
skunk 2 pro series valve springs and titanium retainers
skunk 2 pro 1 cams and pro series cam gears
prelude lmas
ARP head studs
edelbrock victor x intake manifold
id 2000s
aeromotive fpr
golden eagle fuel rail
omnipower 70mm throttle body(still need this) blox 74mm now on order
speedfactory 4 bar map(still need this) now on order
8 an feed line
stock feed line used as new return
new fuel tank(still need to get one) now on order
walbro 450(still need it)
need to get a filter
hasport mounts
comp twin disc clutch (b disc)
go autoworks clutch line
go autoworks radiator(still need fan and shroud)
painted the engine bay black ... now for some pics
Old Sep 5, 2013 | 06:45 PM
boostlsveg's Avatar
Default Re: boostlsveg street/drag eg build
And now for the turbo setup:
precision 6265 t3 with .82ar
afi top mount
tial 44mm
tial bov
precision 750 intercooler
go autoworks intercooler piping(still need to order) this and shaved valve cover will be painted the same color as the car
3an oil feed line(still need to get a restrictor) 10 an return
blox oil filter adapter
The interior is black it was a factory pleather car but I traded the front seats for gsr seats.
momo corse steering wheel(still need to get a hub)
defi blue racer gauges boost, oil pressure, and water temp.
autometer tach(wanting to get a jdm cluster later on a get rid of this)
it is currently gutted but I will be putting the carpet and stuff back in later.
ssr comp wheels 15x6.5-light as **** 205/45 toyo t1r on them right now will have 235/60 et streets on the front when she gets on the road
omnipower full coilovers
blox lcas
have a blox sway bar also but I couldn't get it to fit
traction bars don't remember what brand but I don't really buy cheap ****
tranny is a b16 freshly rebuilt with carbon coated synchros and mfactory lsd
debating on putting in a gsr 4th and ls 5th gear
stock axles for now
Old Sep 5, 2013 | 06:56 PM
boostlsveg's Avatar
more pics some of car in its current state..
eventually im gonna need to get a cage, mayb a chute and deffinately getting a 3 pc front end shortly after we get it done.
Old Sep 5, 2013 | 07:00 PM
boostlsveg's Avatar
will be putting up pics of bottom end tomorrow and head whenever its done at the machine shop.. probably next week. it would've been done today but yesterday when he was trying to put in the guides he realized I ended up receiving d series intake guides by accident but theyre taking care of that so as soon as I get the b series ones hell prolly finish it the next day or so.
Old Sep 5, 2013 | 07:11 PM
boostlsveg's Avatar
I will be running hondata s300 with boost by gear and running e85 for fuel. power goal im hoping to hit is 650-700 whp on around 27 psi and hoping to net a mid to low 10 second et! may be changing to a 60mm wastegate or add another 44 depending if it creeps or not. also by the time it gets finished my fuel pump situation could change and I might b adding kseries coilpacks.
Old Sep 6, 2013 | 06:19 PM
boostlsveg's Avatar
went and got some dei titanium header wrap today and started but they only had 15ft rolls and it was only enough for half lol
Old Sep 10, 2013 | 12:13 PM
BB1 H22A LUDE's Avatar
Thumbs up from me, looks good so far. Any goals in terms of 1/4mile ETs once its all running?
Old Sep 10, 2013 | 03:18 PM
boostlsveg's Avatar
Thanks man..Well if all goes well im hoping to get real comfortable with the et streets n hoping to hit a 10 with them if I can.. But my goal with slicks is a low 10 et at around 140.. On another note I will b adding an ATI race damper n a 4.2 final in case I need some more mph outta 4th gear.
Old Sep 10, 2013 | 04:06 PM
boostlsveg's Avatar
got the head back today. got it put back together for the most part.. tomorrow ill get to the shop n throw the springs in n shell b ready to go on the motor
Old Sep 10, 2013 | 07:54 PM
boostlsveg's Avatar
Forgot to mention that I will b running a bwr catch can which I have yet to buy n a odyssey battery that will b mounted somewhere hidden not sure where yet tho.
Old Sep 11, 2013 | 09:43 AM
ballistic1350's Avatar
interested to see how and where you mount your battery
Old Sep 11, 2013 | 06:22 PM
boostlsveg's Avatar
ballistic speedfactory makes the mount that I will most likely use will be mounted either in the fender or behind the bumper probably..
got the springs in today so hopefully this weekend I can get the motor ready to go in!
Old Sep 13, 2013 | 02:37 PM
boostlsveg's Avatar
got the manifold wrapped up a lil better today.. waiting for another roll to come in the mail n ill finish it. got a couple color options for the car also.. what do u guys think?
Old Sep 15, 2013 | 01:51 PM
boostlsveg's Avatar
got a little bit done today.. got my interior cleaned up a little and put in the car. stills need some armorall also snapped a pic of the bottom end which has 1000 miles on it.
Old Sep 15, 2013 | 11:21 PM
artie89's Avatar
keep up the good work
Old Sep 16, 2013 | 07:13 AM
boostlsveg's Avatar
thanks
Old Sep 16, 2013 | 12:25 PM
Dark_Teg's Avatar
Get rid of the hose clamps and get stainless steel zip ties, much cleaner looking. They even have them in black.
Old Sep 16, 2013 | 02:04 PM
boostlsveg's Avatar
I was at the auto parts and that was the only thing they had that would work.. where can u get the steel zip ties
Old Sep 16, 2013 | 02:39 PM
Dark_Teg's Avatar
I got mine off of Ebay. They hold up well in high heat areas. I have been using them on my cars for 10 years.
Old Sep 16, 2013 | 06:35 PM
boostlsveg's Avatar
thanks man ill have to check that out I was looking at the auto parts for a better way but the hose clamps were the only thing they had that I seen would work.
Old Sep 18, 2013 | 03:15 PM
boostlsveg's Avatar
got my new tank today! was gonna throw it in but decided to prime and paint it before I do since it was bare metal. also got my fittings for my pump hanger since im reusing my old feed as my return im gonna get rid of the old return and put an 8an to 3/8 npt 90 degree fitting in the hanger and put a nut with an oring and using a female 3/8 barb fitting to connect the hose to the pump.. hoping this will work.. I was trying to get some insight from someone who has done it but no one replied and I couldn't find any info so ill be the guinea pig I guess lol also im gonna get rid of the old wiring that comes threw the hanger and run 8 gauge straight to the pump and seal it around the wire.. curious what I should seal it with? if any one sees this and has ideas let me know.
Old Sep 19, 2013 | 09:31 AM
Have you considered some type of undercoating for the bottom of the fuel tank, for durability?
Also glad to see someone else is taking the time to document their build, looking good so far
Old Sep 19, 2013 | 11:05 AM
boostlsveg's Avatar
thanks man... Yea I was debating it but I had some gloss black laying around so I just used that. I may later on tho if it starts to get chipped up
Old Sep 20, 2013 | 07:19 PM
boostlsveg's Avatar
got the tank in today! also ordered my wiring to wire my fuel pump, still need to get a relay and figure out how to wire that up.. will post up some pics when I get it done. also got some 6an fittings to finish my return.
Old Sep 20, 2013 | 08:19 PM
efhatchbackracer's Avatar
Wow, extensive work, im dign it! But i do have 1 question...can u share ur budget w me so i can finish my eh3 hahaha jk. Keep up the awesome work, things gna b SICK
