2000 Accord Starter replacement
Old Sep 5, 2013 | 01:12 PM
mabmab1997's Avatar
Default 2000 Accord Starter replacement
Has anyone seen a good dyi for a starter replacement on a 2000 accord. (maybe w/ pics)
thanks
Old Sep 5, 2013 | 01:18 PM
h0p3l355dork's Avatar
Default Re: 2000 Accord Starter replacement
Starter is pretty simple. Remove bolt on the starter, remove bolt on solenoid, remove three (?) bolts attaching it to the transmission (PB Blaster might be your friend here). Install new one, installation in reverse. One note is to not remove those small 8mm bolts, you want to remove the entire starter assembly. The bolt on the bottom side might be a pain to get to so be sure to have a long 3/8" ratchet extension and a cheater bar. (oh and disconnect the battery > ground wire for your own safety first.
Old Sep 9, 2013 | 10:26 AM
mabmab1997's Avatar
thanks for the info
HAV6
Oct 1, 2007 09:32 AM
tlovaj
Aug 23, 2007 04:17 PM
B bOy CrAyOn
Aug 6, 2007 07:24 PM
Cwhiteg6
Jun 22, 2006 11:56 AM
Creepshow S60
Nov 6, 2003 07:34 PM
