1991 Honda Accord Brake Lamp
Old Sep 4, 2013 | 03:08 PM
gtaylor318's Avatar
Default 1991 Honda Accord Brake Lamp
1991 Honda Accord Dx Brake Lamp stays on
Old Sep 4, 2013 | 09:45 PM
Nytrious's Avatar
Default Re: 1991 Honda Accord Brake Lamp
try checking all the lights in the trunk and see if all are plugged in. this solved my problem
Old Sep 5, 2013 | 07:40 AM
AccordCoupe91's Avatar
If it stays on without pressure to the pedal, take a look at the armature of the brake pedal. There is a small plastic plug that will break and the switch for the break light then stays up and keeps thee brake light circiut on. To remedy this you can try a piece of plastic over the hole and wrap it with electrical tape. Thats a temporary fix. I used a bolt with a nut and put it through the hole which fixed the problem. Good Luck!
asocallocal
Aug 29, 2010 07:00 PM
georgelimas
Mar 15, 2008 05:11 PM
aLaRcOn_87
Nov 30, 2007 04:13 PM
03 Accord Girl
Sep 1, 2007 04:47 PM
teamguerino
Sep 4, 2005 09:38 AM
