Air intake tube
Old Sep 4, 2013 | 03:56 AM
Fitz Williams's Avatar
10 Year Member
Default Air intake tube
I saw that a Prelude intake tube (from air cleaner to throttle body) had a lot less attachments and things on it that my 94 Accord so I replaced mine with one from a 95 Prelude S. I can't tell any difference in the sound or performance, so what is the purpose of all the "things" connected to the Accord tube? I was looking to clean up the engine compartment and this seemed like a good start.
Old Sep 4, 2013 | 11:02 AM
wolfy47's Avatar
Default Re: Air intake tube
They are to reduce the noise that the intake makes.
Old Sep 4, 2013 | 02:13 PM
MAD_MIKE's Avatar
MM Gruppe B
The other thing is that the S most likely has lower gear ratios in it's tranmission to allow for quicker acceleration. Thus the stock Accord tube is tuned for the lower/cruise rpms with the higher gearing.
If anything you may be hurting the stock performance of your Accord by removing the Accord tube. I would leave it in place unless there have been other significant modifications.
Old Sep 5, 2013 | 04:12 AM
10 Year Member
I also took a look at the Gen 6 Accord intake tube and it doesn't have all the attachments on it either. I am thinking that maybe is was an innovation for the Gen 5 Accords that didn't work out. Not good, not bad, just unnecessary. It fees up some space under the hood with all the extra stuff is removed.
Old Sep 5, 2013 | 06:12 AM
NZXTInerTia's Avatar
The 5th gen Accords (not sure about the 4th) had the FIA emissions system that they later ditched. There is always a purpose for something, but that doesn't mean it works properly, or efficiently. I installed an AEM SRI on my Accord before I went boost simply to reduce all the crap that the stock intake has on it.
dcx27
Sep 17, 2016 03:10 PM
951dc5
May 7, 2005 10:39 AM
