b18b1 eagle h beam rods. piston ring gap and bearing question.
Old Sep 3, 2013 | 06:45 PM
10psiLsEf2's Avatar
Default b18b1 eagle h beam rods. piston ring gap and bearing question.
Whats up guys im in the middle of building a lst.
Bought eagle h beam rods and wiseco 81.5 mm pistons
The guy gave me 8 honda bearings 4 are red and 4 are green.
Doea this sound right?
Also what piston ring end gaps? 350 whp max. 9.0:. Cr
Old Sep 3, 2013 | 07:13 PM
jdmh22eg2's Avatar
Default Re: b18b1 eagle h beam rods. piston ring gap and bearing question.
i would run OEM spec ring gap for that mm bore. look for rebuild specs.
honda has MANY diff bearings. you will have to "decode" your crank. look for numbers/letters
Old Sep 4, 2013 | 12:40 AM
m4xwellmurd3r's Avatar
your pistons shouldve come with a spec sheet stating what ring gaps they recommend for different applications. as the rod bearings, you need to look for the letter stampings on your crank. number stamps are mains, letter stamps are rods. I have no idea what size equivilant the eagle rods are, so after you find out what stamping your crank is, plastigauge your rods using the bearings he supplied to figure out if you need bigger or smaller bearings. reds are the smallest and greens are the middle ground.
Posted from Honda-tech.com App for Android
KdEj1
Sep 15, 2012 07:12 PM
orioncivic
Aug 15, 2012 04:36 PM
Mutiny1
Feb 13, 2010 04:26 PM
GoldLudeRay
Sep 13, 2008 03:51 AM
nicklk
Feb 9, 2004 06:41 PM
