Del sol B18C swap motor mount question
Old Sep 3, 2013 | 06:39 PM
matt56's Avatar
Default Del sol B18C swap motor mount question
Hey guys I have searched and haven't been able to find a direct answer for this question, on a 95 del sol Si to B18C swap, which motor mounts you do use? I assume since It's a D series to B swap it would take the B series mounts correct? I just needed to know for sure because I have a motor mount that crapped out on me and I need to be able to tell the shop I am having it replaced at which one to get.
Also just a curious question if anyone knows, when I crawled under my car it looked like it was just the insert that was separated/broken, is it feasible to replace the insert only or is it best to get the whole mount replaced?
Thanks so much if you can help out.
Old Sep 3, 2013 | 06:43 PM
instrument's Avatar
Default Re: Del sol B18C swap motor mount question
same as eg civic, only diff is linkage.
Old Sep 3, 2013 | 07:04 PM
matt56's Avatar
So it's B18C mounts?
Matt Richardson
13
Apr 18, 2019 07:10 AM
civicgsrb18
Oct 25, 2009 04:22 PM
sticest
Apr 26, 2009 03:17 AM
lsdelslow
May 27, 2006 01:36 PM
the-anti-crack
Jun 1, 2005 09:02 AM
