Honda CR-V & Element 2WD & 4WD Element & CR-V
2005 Honda CR-V headlight harness plug problem
Old Sep 3, 2013 | 06:16 PM
TSteidel's Avatar
Default 2005 Honda CR-V headlight harness plug problem
I recently experienced a left headlight failure. Upon investigation, I found that the H-1 bulb was burned out (easy replacement) but, what's worse, the plug in the wiring harness had worked loose, and apparently arced/overheated, causing the plastic plug to partially melt. I've cleaned up what remains of the two-prong harness plug, and the mating two-prong socket, so the light works again...for now. Does Honda sell the wiring harness plug, or do I have to resort to a junkyard to find a used plug from a wreck, in order to provide a more permanent and reliable "fix?"
GrimLude
May 13, 2014 11:24 AM
Pancho2193
Nov 24, 2012 10:02 PM
bdubnyc
Feb 10, 2008 03:27 PM
Wazup
May 6, 2003 10:03 PM
