Honda CR-V & Element 2WD & 4WD Element & CR-V
stock Integra struts and springs on 1gen
Old Sep 3, 2013 | 07:02 AM
ttpjake's Avatar
Default stock Integra struts and springs on 1gen
I want to lower my V just a little bit and keep the drive-ability of stock suspension. With that in mind, has anyone ever tried putting OEM struts and springs from an Integra or Civic? If so, how did it look/feel? Did it fit without modifications?
If nobody's tried it, does anyone have your stock struts and springs to donate for a trial fit?
Old Sep 3, 2013 | 12:41 PM
Phantom240's Avatar
Default Re: stock Integra struts and springs on 1gen
Nope. Won't work with regular RS/GS/GSR teggy suspension. The rears are set up identical to an ITR, meaning the rear struts are incompatible with a CRV. Also, it'll be HAMMERED. Here's how mine sits on Function Form Type Two coilovers raised almost as high as they'll go. Also, the rear has a 2" lift kit bolted to the top of the coilover. This was also before the springs settled down:
Old Sep 3, 2013 | 02:24 PM
FeedBack159's Avatar
10 Year Member
you might have a better chance putting the the stock 02 accord struts and springs in. but you would have to chance the top mount over from the crv to the accord struts because i believe that have a 4 stud mounting on them
Old Sep 3, 2013 | 06:39 PM
squeaks's Avatar
This is what I am going to do, and yes you have to change the top hats
Old Sep 3, 2013 | 07:00 PM
ttpjake's Avatar
Does that apply to both front and rear struts and springs? Does it matter if it's from sedan or coupe? V6 or 4 cylinder?
Old Sep 4, 2013 | 10:35 AM
10 Year Member
i think you only have to swap the front top hats out cause there like a 5 bolt pattern instead of a 2 like out cr-v's. and no it doesn't matter. the 4 from the 6.
Old Sep 5, 2013 | 07:48 AM
squeaks's Avatar
I read that it is better to do both, but hey I am not 100%. and I know the rears have to be ground down a touch on each side of the bottom for them to slide in properly. And you need a accord adjustable camber arm for the rears
Old Sep 5, 2013 | 09:49 AM
Phantom240's Avatar
I think it's an EK camber arm for the rears, though they might interchange and I could be 100% wrong.
Old Sep 5, 2013 | 11:43 AM
ttpjake's Avatar
Do I need the camber arms just because of the alignment or because the struts won't fit without them? I'm on a budget. I want to make subtle changes one at a time. I eventually want to get some kind of 17" OEM wheels so I'm not too worried about tire wear... for now.
Old Sep 5, 2013 | 12:06 PM
ttpjake's Avatar
Speaking of suspension components, while I'm doing the struts, I'm going to change the bushings in the perches and top mounts over to polys. Do I get a poly kit for an EK Si or a DC2? I'm going with Energy Suspension master kit:
http://www.amazon.com/Energy-Suspension-16-18109G-Master-Honda/dp/B000CNAVH2/ref=sr_1_1?s=automotive&ie=UTF8&qid=1378411409&sr=1-1&keywords=Energy+Suspension+16.18109G+Master+Set+for+Honda+Civic+Si http://www.amazon.com/Energy-Suspension-16-18109G-Master-Honda/dp/B000CNAVH2/ref=sr_1_1?s=automotive&ie=UTF8&qid=1378411409&sr=1-1&keywords=Energy+Suspension+16.18109G+Master+Set+for+Honda+Civic+Si
or
Amazon.com: Energy Suspension 16.18105G Master Set for Acura Integra: Automotive Amazon.com: Energy Suspension 16.18105G Master Set for Acura Integra: Automotive
Old Sep 5, 2013 | 05:29 PM
squeaks's Avatar
I think they are the 97 and down accord which is interchangeable with the EG. But again I am just guessing
Old Sep 6, 2013 | 05:53 AM
Phantom240's Avatar
I dunno about the camber arms interchanging with an EG, but I know that every other component of the suspension from a 5th gen Accord (94-97) is NOT compatible with any Civic, and only a couple parts are compatible with a 4th gen Prelude (92-96).
Old Sep 6, 2013 | 12:24 PM
ttpjake's Avatar
I feel a little thread jacked lol. I'm gonna go with a full set of 02 accord strut assemblies. But which poly set would be better? I assume the 99 Si set?
Also, what rear upper strut tower bar works? DC2?
What rear lower tie bar? EG?
I know the front upper strut bar from a DC2 works... if I didn't have the effin intake manifold resonator in the way
Old Sep 6, 2013 | 01:14 PM
Phantom240's Avatar
I don't think we can use any of the production rear lower tie bars. Once you get underneath, you'll see why I say that.
bennyBronco
Oct 23, 2011 09:42 AM
rekreb38
Suspension & Brakes
Nov 3, 2010 10:30 AM
b18bregean
Aug 2, 2008 04:15 PM
wuggiewuggie
Suspension & Brakes
16
Apr 19, 2007 09:44 AM
mos
May 25, 2003 09:57 PM
