spoiler brake light flash?
ive seen write ups for other cars to make the 3rd brake light on the spoiler blink when you apply the brakes,
I cant find a write up for an integra but I found one for a 95 civic stating all you have to do is splice in a turn signal flasher into the hot wire $4 from advance,
I tried it and the light just stay on constant. does anyone know why it don't flash? or how to make it flash?
94 LS integra-
94 LS integra-
FYI I figured out the problem, if anyone else see's this issue it is because the LED 3rd brake light does not have enough resistance. I connected the halogen light and it worked correctly,
wire a resistor into the circuit and it should work correctly.
JsCvCVtechSI
Mar 16, 2004 08:18 PM
Minorgliche
Nov 18, 2002 09:40 PM
