91 B18 Swap questions
Old Sep 2, 2013 | 08:58 AM
nizle144's Avatar
Default 91 B18 Swap questions
I just picked up a a 91 CRX that has had a B18A1 bottom end and B18C top end swap. I has a P28 ecu. I just found a switch in the glove box that turns the CEL on and off. The first issue i found is that when the car gets up to operating temp it starts to idle real ruff when i come to stop, and has died but will start right back up. I have taken off the IACV and cleaned it but there was no change. Should i be able to move the piston in the IACV back and forth or not? And it also has a FITV block off plate of it. Need some input!
martn53
15
Nov 23, 2009 11:05 PM
mr. carpenter
Sep 8, 2002 09:05 AM
