Honda CR-V & Element 2WD & 4WD Element & CR-V
Hit bump and radio turned off!?!?
Old Sep 1, 2013 | 05:25 PM
FeedBack159's Avatar
10 Year Member
Default Hit bump and radio turned off!?!?
ok so i was driving and in a construction area. I hit a huge bump and my radio instantly turned off. any ideas why this would happen? thank you!
Old Sep 1, 2013 | 05:34 PM
Sticker Bomb's Avatar
Default Re: Hit bump and radio turned off!?!?
Wires are touching some where most likely. Remove the radio and check the wiring to make sure everything is fine, and if so. The radio could be done now.
Old Sep 1, 2013 | 05:58 PM
10 Year Member
even if the fuse is alright?
Old Sep 1, 2013 | 07:09 PM
10 Year Member
I just noticed the clock on the dash is out too. It doesn't seem it be a fuse.
Old Sep 1, 2013 | 10:14 PM
77777's Avatar
something jiggled lose or shorted, maybe even internally in the radio? I had a 1990 rx7 that came with shitty deck that would turn off over the slightest bump.
Old Sep 1, 2013 | 11:21 PM
10 Year Member
yea it seems like im getting voltage on the harness for the radio. but why would the dash clock be out?
Old Sep 2, 2013 | 08:20 AM
jayjazmin's Avatar
This happened to my clock a couple days ago..it went off after going through a dip.. 3 minutes later it came back on.. weird
Old Sep 2, 2013 | 09:38 AM
10 Year Member
soo hit another bump? hahah
Old Sep 2, 2013 | 01:34 PM
jayjazmin's Avatar
If fuses are good then its just wiring that went all crazy after hitting a bump. Try hitting another bump lol. Or u can try resetting your battery. N see if that does anything
Old Sep 2, 2013 | 05:49 PM
10 Year Member
do you think its possible that a clip came undone somewhere behind the radio or the dash?
Old Sep 2, 2013 | 08:21 PM
jayjazmin's Avatar
If it still hasnt come on yet. Id inspect it. Take it apart n double check wiring.. hope you know that just to get to the radio is a b****. Lol thats if u havent done it before.
Old Sep 3, 2013 | 10:35 AM
10 Year Member
everything fixed! there was a blown fuse under the hood. i didn't look there because i figured it would be on the cabin fuse board. and there also was a loose wire on the radio. that probably touched something and shorted. thanks for the help!
ennah
Sep 26, 2011 08:58 AM
egyolk
Aug 9, 2005 08:47 AM
egyolk
Jul 8, 2005 05:24 AM
CHIA
Jan 11, 2005 12:12 PM
