car is suddenly slow and smokes
Old Sep 1, 2013 | 01:44 PM
luder23's Avatar
Icon2 car is suddenly slow and smokes
my car is suddenly slower and smoke alot when i get passed 5 rpms. sometimes after getting on it, it smokes at idle. but not till after i get on it. where should i start looking? head gasket, rings, valve seals? idk where to start
Old Sep 1, 2013 | 04:41 PM
B_Swapped93's Avatar
Default Re: car is suddenly slow and smokes
compression test it post the number then go from there. WET & dry test then leakdown
Old Sep 1, 2013 | 09:21 PM
luder23's Avatar
ok where do i get this done, and how much does it cost?
luder23's Avatar
just any regular shop?
Old Sep 2, 2013 | 12:23 AM
You can rent a compression tester for free or buy one for 20$.
Old Sep 2, 2013 | 09:15 AM
wayneDOHC's Avatar
yeah just to it yourself. its very simple. there are plenty of threads on here on how to do a compression test and the part in only about $20. a wet compression test will tell you right away if your rings are good or not.
Old Sep 2, 2013 | 05:32 PM
KILLAB17VTEC's Avatar
Genetically Gay
Replace rings.
Old Sep 2, 2013 | 05:49 PM
racebum's Avatar
make sure to disconnect the distributor when you do the test!
very important step unless you want to fry the coil
Old Sep 6, 2013 | 06:07 PM
luder23's Avatar
just buy it from autozone? id rather do it myself than pay someone to do it
Old Sep 6, 2013 | 06:32 PM
ya or rent it but it's a VERY handy tool to have imo so just sent 20$. I once had a garage comp/leakdown test a car I had once NOT by choice either ! they charged me 65$ which is nuts never went back there.
turbosivtec
May 24, 2009 04:33 PM
humboldt_skim
May 31, 2008 08:18 AM
94_civic_tuner
Oct 10, 2007 02:00 PM
racingant
Dec 6, 2005 08:03 AM
